1. mysamsungs7e's Avatar
    And do we need it!
    12-13-2016 12:35 AM
  2. chanchan05's Avatar
    No. It just creates a locked down encrypted area on your phone where you can keep stuff so no one can access them without your permission.
    anon(632115) likes this.
    12-13-2016 01:19 AM
  3. Dngrsone's Avatar
    Knox is Samsung's security module. It is a quick way to for your provider and Samsung to tell if you have rooted or modified the firmware on your phone. I'd leave it in place until your warranty expires.
    12-13-2016 06:33 AM
  4. anon(632115)'s Avatar
    That is not the purpose of Knox as some root methods don't trip it, chanchan05 is on the money with his answer
    12-13-2016 06:40 AM
  5. mysamsungs7e's Avatar
    I can't seem to disable it
    12-13-2016 02:02 PM
  6. natehoy's Avatar
    Knox is, in essence, part of Samsung's operating system. It has hooks for mobile device management, security risk mitigation, and areas where you can store encrypted data (and your employer can also store encrypted data if you hook Knox to a Mobile Device Management solution). It's not something you really want to get in to disabling unless you are ready to just load a third-party ROM without Knox on board.
    12-13-2016 03:58 PM
