1. Floridadomer's Avatar
    Is there a way to get rid of that stupid Video icon on the dialer?
    12-13-2016 11:13 AM
  2. sweetypie31's Avatar
    Not that I can see. The only thing I found in the settings was a way to turn it off, but it still stays on the dialer.
    12-13-2016 03:44 PM
  3. Floridadomer's Avatar
    Thank you. I turned it off but I was hoping to be able to hide it.
    12-13-2016 03:47 PM
  4. Nakrohtap's Avatar
    Are you using themes? Themes change fonts and colors, but also change the icons in some stock apps like the dialer.
    12-14-2016 05:26 AM
