1. N7AS's Avatar
    Just got my Galaxy S7 Edge yesterday and noticed that the AOD is very dim to the point I can hardly see it. I use the calendar.
    12-14-2016 03:15 PM
  2. amyf27's Avatar
    What's your brightness setting on? If it's auto then it likely will be dimm
    12-14-2016 03:38 PM
  3. N7AS's Avatar
    Auto is not checked the bar is at max.
    12-14-2016 04:51 PM
  4. amyf27's Avatar
    I wonder if there is a brightness setting within always on app specifically
    12-14-2016 04:58 PM
  5. N7AS's Avatar
    I looked, and there is none.
    12-14-2016 05:16 PM
  6. clownin72's Avatar
    I wish there was a setting to adjust. I think you get what you get. Sometimes it's bright, others it's so dim you can barely see it
    12-15-2016 12:06 PM
  7. dan lavender's Avatar
    There are no settings for it and it is auto adjust. Go out when it's sunny and it will be brighter but at night it's dim. Would use much more battery if they made it bright all the time so to keep within the 1% per hour they have to make it dim
    12-26-2016 04:17 AM
