1. PencilBoy99's Avatar
    I somehow accidentally did something that allowed me to see a current message conversation in a smaller rectangle on top of my screen, but I could still see the rest of the screen and do other stuff. However, I can't figure out how I did this. How can I do this on purpose. It's really cool.
    Galaxy s7 Edge, AT&T, latest update
    12-15-2016 04:11 PM
  2. chanchan05's Avatar
    It comes out when you receive a measage. It's a popup notification.
    12-15-2016 04:19 PM
  3. Javier P's Avatar
    Welcome to the forums. You can enable/disable these pop-ups notifications for any app. Try this. Go to settings - notifications - advanced, top right - select app and toggle the 'Previews in Pop-Ups' Option On/Off.
    12-15-2016 04:24 PM
  4. jlo3378's Avatar
    Do you mean like the image? If so, you swipe at an angle from the top right or top left corner. You'll see a blue outline that will show what the size of the window will be.
    12-15-2016 05:46 PM
