1. Air Planet's Avatar
    Anyone can suggest me best Samsung Galaxy S7 Edge Clear back Cover & Screen Protector?
    what you think about Spigen crystall shell or Ringke fusion clear back cover or suggest any other?
    Jay Sacks likes this.
    12-17-2016 12:44 PM
  2. jejb's Avatar
    I'm using the Speck clear Candy Shell back cover. Great fit and feel, and I'd recommend it. I don't use a screen protector, though. No scratches or micro-scratches on mine so far.
    12-17-2016 01:00 PM
  3. Jay Sacks's Avatar
    Taken Galaxy S7 Edge Screen Protector [3-Pack] - HD Ultra Clear Film - Anti-Bubble Edge to Edge Screen Protector for Samsung Galaxy S7 Edge https://www.amazon.com/dp/B01ICS0S08...cUvbUpU5611304
    These really worked great and if you are lucky.. can't even tell there is a screen protector. Fits edge to edge. Needs a little work getting bubbles out.
    Sorry but no recommendation for back. I used a minimal clear soft plastic case.
    Air Planet likes this.
    12-17-2016 01:02 PM
  4. Air Planet's Avatar
    Any other
    12-17-2016 05:11 PM
  1. [FREE APP]Full Screen Pic Picture Viewer.
    By cb56 in forum Android Apps
    Last Post: 07-16-2020, 03:03 AM
  2. Replies: 1
    Last Post: 12-17-2016, 04:50 PM
  3. how to copy archived voicemails to computer from Galaxy S5?
    Last Post: 12-17-2016, 04:12 PM
  4. S7 Active USB port not passing Internet
    Last Post: 12-17-2016, 01:43 PM
  5. Half screen
    Last Post: 12-17-2016, 01:24 PM
