1. Air Planet's Avatar
    Have u tried or know these two cases if yes then tell me which is better i want total clear case for s7 edge?
    12-18-2016 03:23 AM
  2. anthony2558's Avatar
    I've always preferred ringke fusion. I like that it has covers for the head phone jack, and charging port. I like them because it feels better covered when holding the phone.
    12-18-2016 02:03 PM
  3. Air Planet's Avatar
    No one using clear cover for s7 edge?
    12-31-2016 01:54 PM
  4. john905r's Avatar
    i am using the Ringke fusion case. i also have the Spigen case too i just like the Ringke case better!!!!!!!!
    12-31-2016 06:00 PM
  5. Air Planet's Avatar
    Are u using spigen crystal shell clear or other?
    01-01-2017 05:20 AM
  6. Lepa79's Avatar
    I'm not a big fan of clear cases. They get so smudgy and dirty. I use spigen rugged armor on every phone I have. Best case I have used and I used many. Highly recommended.
    Spigen Rugged Armor Galaxy S7 Edge Case with Resilient Shock Absorption and Carbon Fiber Design for Samsung Galaxy S7 Edge 2016 - Black https://www.amazon.com/dp/B01A7IDHOU...cUvbUpU5628399
    01-01-2017 10:05 PM
  7. djepperson1's Avatar
    I am using the spigen crystal case but it's the neo hybrid. It has the better frame I have always used their crystal cases with zero issues
    01-02-2017 08:27 AM
  8. mrf430's Avatar
    My friend has the Spigen, it's not bad, but I wanted something with better protection so I got this and I really like it:
    https://www.amazon.com/SUPCASE-Unico...cUvbUpU5630430
    It's a great case, slim, strong, and adds very little bulk to the phone.
    01-03-2017 06:41 PM
  9. Air Planet's Avatar
    https://www.amazon.com/SUPCASE-Unico...cUvbUpU5630559
    https://uploads.tapatalk-cdn.com/2017...d3124b9a71.jpg
    https://uploads.tapatalk-cdn.com/2017...eacbce0969.jpg
    https://uploads.tapatalk-cdn.com/2017...661bb38348.jpg
    https://uploads.tapatalk-cdn.com/2017...e816d55a77.jpg
    Thanks but i want full clear cover at back side
    01-03-2017 09:11 PM
  10. Air Planet's Avatar
    And oversll protection wise which is better uag,spigen,ringke,otterbox,vrs design or anyother?
    01-29-2017 03:07 AM
  1. Help with a high capacity microSD card? Formatting issue, or counterfeit?
    By pleasant_nightmares in forum General Help and How To
    Last Post: 12-20-2016, 11:34 AM
  2. How do I know my phone has been hacked or not?
    Last Post: 12-18-2016, 02:13 AM
  3. Replies: 0
    Last Post: 12-17-2016, 11:38 PM
  4. how to disable or turn off battery notification
    Last Post: 12-17-2016, 04:01 PM
  5. Replies: 1
    Last Post: 12-17-2016, 02:09 PM
