01-03-2017 09:39 PM
26 12
tools
  1. Air Planet's Avatar
    Anyone know samsung fast wireless and non wireless charger have
    Overcharge protection for s7 edge and wireless charger too?
    Fast wireless charger plug in hours or 24 hours?
    12-18-2016 03:29 AM
  2. B. Diddy's Avatar
    You can't overcharge a device, because the device will draw as much current as it needs. The charger doesn't "push" charge into the device.
    Dngrsone likes this.
    12-18-2016 01:50 PM
  3. Dngrsone's Avatar
    So far, the battery charging experts agree that fast-charging and wireless charging will shorten battery life because both methods heat up the battery now than a slow charge does.
    So, if you are planning on charging your phone overnight, I'd go with a slow charger. If you are an on-the-go type person who can only afford to put the phone on a charger for only fifteen minutes at a time, then consider a fast-charge or wireless charger.
    If you go with a wireless charger, then pick one with active cooling (a fan).
    12-18-2016 03:40 PM
  4. Air Planet's Avatar
    Active cooling charger means samsung wireless charger official?
    12-18-2016 04:00 PM
  5. Dngrsone's Avatar
    This one has a fan in it, I know.
    12-18-2016 04:15 PM
  6. B. Diddy's Avatar
    I wonder if there have been head-to-head comparisons over time between fast charging and regular charging. I've always figured that fast charging may have an impact on battery life, but I thought that in the grand scheme of things, it wouldn't really impact the average user (since the average user upgrades phones at least every 2 years).
    12-19-2016 12:43 AM
  7. Dngrsone's Avatar
    That's a good question, and a tough one to answer.
    After all, every user is different, and even being able to ascertain average usage and behavior is difficult.
    The. Q-charge technology is still fairly new, and every generation gets its improvements, but I'd venture to say that yes, by the time the average user would tend to notice a battery issue, they are ready to replace their phone anyway. I think that's what manufacturers are counting on and why they are okay with non-user-removable batteries and quick-charging schemes.
    There will always be those who will want to use their equipment beyond engineered life spans, and those people will find ways to get around the battery issue, among other problems.
    And, of course, there are those who will throw a ruckus over any real or imagined quality issue, because that is their thing.
    Personally, I fall into the former category. Additionally, I am a teacher, so I try to inform people of both good and bad qualities of a product so that they may make somewhat informed decisions.
    Sometimes I do over-simplify things for the sake of readability (and short attention-spans) and I get called out for that.
    B. Diddy likes this.
    12-19-2016 06:43 AM
  8. Tachead7075's Avatar
    Just use your phone as you see fit. If the battery life becomes a problem after a couple of years then just change it. It is not very difficult to change the battery on the S7 Edge and it only costs about $10 for a replacement. If you don't feel comfortable doing it then I am sure you can find someone to do it for you.
    https://www.google.ca/url?sa=t&sourc...wWWmdfWM_PaWeA
    12-19-2016 08:41 AM
  9. Air Planet's Avatar
    I means if i plug in 24 hours samsung fast wireless and wall charger then is it good for these chargers to get any issue due to 24 hours plug in?
    12-31-2016 01:53 PM
  10. chanchan05's Avatar
    I charge fast at work when needed during duty , and regular at home. I also tested how big the difference is by draining to 5% and full charging. The fast charge goes from. 0-60 faster than regular charging, but slows down afterwards. Overall it shaves about more than 20min of charging time from 5 to full.
    Impact on battety life can't say. The only time I know definitely fast charging can affect battery life is if the phone heats up, but mine barely heats up when fast charging.
    12-31-2016 06:14 PM
  11. jaltman's Avatar
    Charging rates are controlled by the phone, not the charger. All chargers will be reduced to a slight trickle when the phone is full and barely charge just enough to maintain full. 24 hours on a charger will not be harmful.
    01-02-2017 05:46 AM
  12. Air Planet's Avatar
    Thanks but i am asking about these 2 chargers wall and fast wireless... 24 hours plug in issue?
    01-02-2017 08:49 AM
  13. chanchan05's Avatar
    He said ALL CHARGERS.
    The only issue is if your phone is heating up.
    01-02-2017 09:04 AM
  14. Air Planet's Avatar
    Sorry sir an asking about these 2 chargers (samsung fast wireless charger and fast wall charger) facing issue if it will be plug in wall socket for 24 hours?
    01-02-2017 03:50 PM
  15. B. Diddy's Avatar
    Perhaps you could clarify your question further, because it seems to have been answered more than once. Are you asking if there are any risks to keeping your phone on your Samsung fast wireless charger for 24 hrs straight compared to the plug-in fast wall charger? If so, then the answer is no, as long as your phone isn't heating up excessively during charging.
    01-02-2017 11:12 PM
  16. Air Planet's Avatar
    Dear many times asking about chargers protection if just plug in 24 hours these chargers without any use?
    01-02-2017 11:16 PM
  17. chanchan05's Avatar
    You also have been answered many times.
    This is the third time you will be answered that chargers do not harm your phone even if plugged for 24hrs.
    01-03-2017 12:18 AM
  18. Air Planet's Avatar
    Again you understanding wrong dear
    Dear i am asking about not phone 24 hours plug in harm am asking about these charger 24 hours plugin harm?
    01-03-2017 01:10 AM
  19. chanchan05's Avatar
    How many times do we have to say that plugging phones to chargers for 24hrs doesn't harm them?
    It's you who is not understanding. Chargers do not harm phones even if you plug them for 24hrs. Doesn't matter what or who made your charger.
    01-03-2017 01:34 AM
  20. B. Diddy's Avatar
    I'm afraid you're still not being very clear to us. Are you asking if there is harm to the chargers themselves if they're kept plugged in constantly? If that's your question, then the answer is also no.
    If that still isn't what you're trying to ask, then perhaps you could use the Google Translate site to input your question in your native language, then copy and paste the English translation?
    Almeuit likes this.
    01-03-2017 01:37 AM
  21. Air Planet's Avatar
    Thanks is was that my question means related to chargers
    Anywat Thanks Dear😀😂
    01-03-2017 12:50 PM
  22. Almeuit's Avatar
    Relax -- we were just misunderstanding the question. They meant the actual charger being plugged in for 24 hours not just with a phone attached .
    01-03-2017 01:07 PM
  23. Air Planet's Avatar
    Yes thanks a lot dear you are right but i dont how others are not understanding this🤔
    01-03-2017 02:14 PM
  24. chanchan05's Avatar
    Because you're English isn't very good.
    Again. No issues if the charger is left on the plug, provided your house does not have electrical problems.
    01-03-2017 04:03 PM
  25. Air Planet's Avatar
    T
    01-03-2017 04:06 PM
26 12
  1. Can the screen sensesitivity level be changed on a Samsung Galaxy J7?
    By amigaloca in forum General Help and How To
    Last Post: 12-25-2016, 02:44 AM
  2. Replies: 1
    Last Post: 12-18-2016, 01:32 AM
  3. Samsung Galaxy s4 battery won't hold a charge
    Last Post: 12-17-2016, 10:20 PM
  4. How can I make the keyboard bigger on my Samsung Galaxy J7?
    Last Post: 12-17-2016, 09:03 PM
  5. Replies: 0
    Last Post: 12-17-2016, 07:24 PM
