1. Simon_y7's Avatar
    What is the most comprehensive and safe way to transfer the entire content from one Android to another, in my case from Note 3 to S7 Edge?
    12-19-2016 08:45 PM
  2. chanchan05's Avatar
    Samsung to Samsung. Hence SmartSwitch + Helium Backup.
    12-19-2016 09:26 PM
  3. Rongwey's Avatar
    Samsung has an app that says it will do just what you're asking. Hope it helps.
    Samsung Smart Switch™: Transfer Contacts, Music & More
    12-19-2016 09:28 PM
  4. Simon_y7's Avatar
    I wonder if it makes a difference that some content (incl. apps) is on the memory card.
    12-20-2016 07:44 AM
  5. Tachead7075's Avatar
    12-20-2016 07:58 AM
  6. Dngrsone's Avatar
    If you are switching providers, you may want to go through the app list and make sure not to transfer over the old provider's bloatware...
    Simon_y7 likes this.
    12-20-2016 08:27 AM
  7. Simon_y7's Avatar
    Is there any merit in not transferring apps that way, but having them installed anew through Google Play Store?
    12-21-2016 08:28 PM
  8. Simon_y7's Avatar
    Can Smart Switch transfer selected apps or is it all or none?
    12-27-2016 12:20 PM
  9. Dngrsone's Avatar
    Verizon's transfer app allows one to pick and choose, though it seems to ignore some apps.
    If you are using the same Google account between phones, then you can download all your apps without having to pay for them a second time.
    Also, if you open up the play store, go to My Apps and the All Apps tab, you'll have a list of everything you've downloaded before.
    01-03-2017 10:35 AM
  10. thecomicbookandme's Avatar
    "Quick connect ". Already part of the S7 software.
    01-03-2017 10:49 AM
  11. Amber Glatz's Avatar
    Try SmartIO App , I have found it the most comprehensive and safe way to transfer the entire content from one Android to another Android device
    01-27-2017 12:33 AM
  12. Amber Glatz's Avatar
    It handles contacts duplication too
    01-27-2017 12:37 AM
  13. Daniel Barrett's Avatar
    My S7 came with an adaptor to plug my old phone (Note 4) into it and as soon as I did so it asked me what items I wanted to transfer and it was a done deal, very simple. Maybe that was smart switch? I'm not sure but it was easy
    01-27-2017 08:35 AM
  1. Need help on how to root Galaxy S5 SM-G900I on 6.0.1
    By PolygonError in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 01-06-2017, 03:31 AM
  2. Purchased new phone..levels don't transfer.
    Last Post: 12-20-2016, 03:28 AM
  3. Replies: 1
    Last Post: 12-19-2016, 05:55 PM
  4. why is my phone stuck in greyscale?
    Last Post: 12-19-2016, 04:52 PM
