1. bandofbrothers2112's Avatar
    Hi.
    I've just set up Android Pay on my phone in the UK.
    In the Tap and Pay Section in settings their is two options to choose from.
    1st is the logo of my bank.
    2nd is Android Pay.
    Which do I choose ?
    Also.... Does Android Pay not need my fingerprint on the sensor when using. The guidelines suggest not.
    12-20-2016 04:47 AM
  2. tgp's Avatar
    I'm not sure what your bank's logo means. Usually, more than one option in the Tap and Pay section means that more than one pay option is available. Does your bank offer a tap and pay solution itself? If you want to use Android Pay, choose Android Pay. Mine shows Android Pay and Samsung Pay. I am currently using Samsung Pay because of their new Rewards system, but this is where I choose which payment method I wish to use by default.
    Android Pay does not need verification once the phone is unlocked. It uses the phone's security as its security. In fact, you cannot even activate Android Pay if you do not have security activated on your phone. If after activating Android Pay you turn off your phone's security, Android Pay will deactivate.
    When I was using a Nexus 6P, all I did to pay was touch the fingerprint reader, and tap. You do not even have to open Android Pay. It will activate when the phone is unlocked and it detects an NFC payment reader.
    bandofbrothers2112 likes this.
    12-20-2016 07:19 AM
  3. bandofbrothers2112's Avatar
    Under Nfc and payments in settings.
    12-20-2016 07:52 AM
  4. Gary_Berg's Avatar
    I bet the HSBC app is installed and has its own payment for system.
    12-21-2016 10:46 AM
  5. bandofbrothers2112's Avatar
    Yes spot on I have the HSBC App already installed.
    So should I leave the Android Pay option ✔️
    12-21-2016 10:59 AM
  6. tshirttan408's Avatar
    I have the same, I have the android pay selected. You don't need to keep your fingerprint on the scanner, the app will work as long as your phone is unlocked.
    12-22-2016 05:42 AM
  7. aldo82's Avatar
    I'm not sure you even need the phone unlocked, just the screen lit up? I'm sure I've used it that way on the underground. I think for low cost items less that £30 that contactless works with then you don't have to unlock
    12-22-2016 06:32 AM
  8. tshirttan408's Avatar
    I'm fairly certain it has to be unlocked to stop someone randomly taking your phone and just using it to pay for things
    12-22-2016 07:36 AM
  9. bandofbrothers2112's Avatar
    Update.
    I've chosen Android Pay as shown in my attached picture above and used it to pay for items for the first time yesterday.
    No issues.
    I had to wake the phone to use it.
    Payment was a small amount. £4
    My bank says I'd need to Unlock the phone for payments over £30.
    12-23-2016 02:30 AM
  1. Replies: 3
    Last Post: 12-20-2016, 06:28 AM
  2. MMS issue on G935FD
    By fuzio1963 in forum Samsung Galaxy S7 edge
    Last Post: 12-20-2016, 01:51 AM
  3. Replies: 0
    Last Post: 12-19-2016, 10:53 PM
  4. Rooted my s7 numerous apps have stoped
    Last Post: 12-19-2016, 10:29 PM
  5. Can't log in my Google Account on my device.
    Last Post: 12-19-2016, 10:25 PM
