02-07-2017 02:14 PM
55 123
tools
  1. steelers1's Avatar
    Apologies - my bad.
    Do you have an SD card installed? If so, have you tried removing it and seeing how the battery does? It's odd that Media Server is running so much when you aren't doing anything - a corrupt or "bad" file on an SD card can cause that (I've run into that in the past, as have others).
    Yes I have an SD card installed. I've had the same problem with media server on this phone and my s6, but not on my note 7. The only time media server shows up like that is when I play music on my phone which is usually the first hour and a half of work. All the music is local from Mp3's.
    01-21-2017 10:31 AM
  2. Dngrsone's Avatar
    You must be lucky then, because I have had a chronic problem with Google Play Music turning itself on without prompting with every single Samsung phone I've owned.
    01-21-2017 12:03 PM
  3. steelers1's Avatar
    Still trying to figure out why my battery life is so bad. After being off the charger for 6 hours and only a half hour of screen on time I'm down to 50% no matter what I try. I do notice that Gsam reports a ton of use from Wifi being on while I'm at work and not connected to WiFi. I don't want to have to turn off Wifi every time I leave the house.
    02-07-2017 12:56 PM
  4. rcrc001's Avatar
    It's that Android System app. I'm still trying to figure out which app is triggering it to run.
    02-07-2017 01:01 PM
  5. steelers1's Avatar
    I think you're right. I just can't figure it out
    02-07-2017 02:14 PM
55 123
  1. How to remove Win Jackpot popup from phone
    Last Post: 09-02-2017, 02:39 PM
  2. Should I upgrade my Nexus 5X from 6.0.1 to 7.1.1?
    By Michael Rife in forum Nexus 5X
    Last Post: 12-22-2016, 05:00 AM
  3. Replies: 1
    Last Post: 12-20-2016, 02:10 PM
  4. Why cant I save pictures from fb to my s6 now?
    Last Post: 12-20-2016, 12:54 PM
  5. Replies: 0
    Last Post: 12-20-2016, 11:56 AM
