Bought an s7 edge to replace my Note 7 and have been slowly trying to switch to the edge. I still have my Note and it gets amazing battery life. I have my S7 edge setup almost identical to my Note 7, probably a little less stuff on the S7. I took the S7 off the charger at 100% at 3 am and it sat untouched on my nightstand until 5:30 am and has dropped to 91%. By noon it was at 41% with under 15 minutes of use. I took a screenshot of Gsam battery monitor but can't seem to pinpoint what is causing it. This phone should be the same or better battery wise as my Note 7 was.
I agree. My Note7 battery was great. Loved the phone. No complaints at all other than Samsung telling me it was going to explode. The battery on my S7E, while larger in capacity, is mediocre at best in comparison. My N7 would be down around 60% by the end of a 10h shift in the ER, but my S7E is always well below 50%. While a good phone, I really can't wait to get rid of it for hopefully an S8. I had no problems with my N7, but have already had to get a replacement S7E because my last one stopped wirelessly charging. My current one is now not charging on my Tylt charger. Coming from a long list of Droids, it's all given me kind of a bad taste for Samsung.
Well, something is wrong then I think. My phone has been on for 7.5hours today with maybe 30min on screen use and it is at 79%. I have location services, NFC, and Bluetooth off but Sync and Wifi on(I have been in WiFi range most of the day).
Someone in another thread discovered that an excessively large cache (he had downloaded music through Google) can cause battery usage problems for some strange reason.
Also, if you are in a low signal/connectivity area, this will burn battery.
On my TYLT charger I have found that I have to turn the S7E sideways for it to charge...kind of annoying but it works.
I have the opposite experience. I had a Gen 2 N7 for about 10 days before the final recall. It's battery life was worse than my S7E, something that surprised me when I went to the S7E. I took mine off the charger at 7am and 12 hours later it's at 85% with almost an hour of SOT and running it as a hot spot for 45 minutes. Admittedly light use day, but still amazing to me. Overnight, it will lose 2-3% max in 8 hours. My N7 was not horrible, but certainly not as good as my S7E.
My guess is you have some kind of rouge app, but it would be a good idea to clear both of your caches, the one under Settings-Storage and the one in the recovery menu.
I have NFC off and location is on power saving but Sync, Bluetooth, and WiFi on. I was on WiFi when I lost 9% while sleeping with the phone on the nightstand. I was at work the rest of the time where I have good signal. My old S6 is the exact same way. The two different Note 7's I had were both great.
Saw that but I don't download music from Google play and I have very good signal.
Saw that, but I don't download music from Google and I have good signal.
Something must be drawing down your battery for sure then. Maybe an app? Unless you got a bad battery? My phone has now been on for 12 hours 29 minutes and it is still at 64%. I have been on it a fair amount today too. Almost 4 hours screen on time.
Your light use day is extremely heavy for me. Hell, with that kind of use my s7 edge would be at 25% and my s6 would be dead by noon lol. My thoughts were a Rouge app too, that's why I posted screenshots of Gsam but I'm not seeing anything are you? It looks like android kernel and system are the culprits to me. I have already cleared the cache in recovery and got no change. What is the difference between the cache in Settings?
Your phone has a great many caches... Here is a tutorial that may be of use.
I may be wrong, in fact I frequently am, but considering your symptoms and the fact that you can't pinpoint the problem, this seems as likely as anything else.
BUt the odd thing is that it WAS working fine and suddenly stopped charging on both the Tylt and my car's AirDock and its not like either of them have moving parts to break. I'll set it on one of them, it will make the connection noise and screen visual and after about a minute will disconnect from charging. I'll try the sideways thing tonight.
It can be hard to find apps that are draining the battery, especially with an un-rooted phone. My Nexus 6P was rooted so I was able to employ more tools to figure out which apps were messing up the battery life, but even then it was not always straight forward. Weather Bug and MyRadar were two that always seemed to be an issue. i-exit was at times, too, at least on the 6P.
So no easy answer to this one. I've seen some suggest doing a factory reset and only loading a few apps at a time to try to pinpoint the problem child. I think I'd start deleting apps a few at a time, dumping cache and rebooting to see if I could figure it out that way before doing a reset, personally.
I'm not sure what the difference is between the Cache under Settings->Storage and in the recovery menu. But I clear them both on a regular basis, more so the one under Settings, since I don't have to boot the phone to do it. My wife's Note 3 had over 10gb in that cache at one point, eating up her internal storage, heavily impacting her battery life and way slowing down the phone. Since I cleaned that up, it's like a new phone. So it's become something I just do now.
Just to add, the software on the Note7 is not identical to the S7E. I believe there's a lot more device optimization on the Note7, which has made its way to the S7 Beta as well.
I love the freedom and the fact that Android is open source. Customization to make your device as simple or complex as I want. Themes, icons, SD cards. I love it all.
Battery management might be an art meaning that everyone has a different interpretation as to what "decent" is. Or it might be a science in which we are searching for the formula that ensures the best battery life possible. However, with so many variables, the formula can never be the same unless users are running the same apps, on the same service, in the same location, with the same radios turned on, etc.
All I want for Christmas...(probably in 2017) is to forget about managing a battery and let the software determine what's best based on my habits.
I'm not sure whether or not to be surprised by this.
By nature (large battery), your S7 Edge should be giving you fantastic battery life, mine certainly is doing a great job of it, I easily get 6-7hours SOT
with a mix of 4G LTE and WiFi, while I get up to 9hours if I'm mostly on WiFi.
With that said, the below has to be considered:
And with this taken into consideration, I think the S7 Edge will be much better in Nougat.
In fact I think the S7E will be better than what the Note7 was after Nougat Update, as it has the larger battery and less processes (no SPen, Iris Scanner etc... To run).
I hope Nougat doesn't mess up battery life. It certainly did in the Nexus 6P world. But I think they have a better handle on it now. One of the advantages of getting Nougat later than some others is a (hopefully) more stable release. It was mess in the 6P world at first. That was my first experience with the a Google phone and "getting the updates first". I learned it's not always good to get the updates first. You're just Beta testing for Google a lot of the time.
As I said above, my S7E is better on battery life than my N7 was. By far, the best battery life of any phone I've owned. Maybe it was a Gen2 N7 thing, though. I always wondered if they'd rushed the re-release a bit.
