1. Thomas Gruver's Avatar
    I have an alpine deck in my car that has worked fine for the last year plus. Suddenly, a few months ago, the mic will drop out when on a call, even though the phone still shows connected.
    No changes to the deck....had the dealer look at it as well.
    Any thoughts appreciated. I did try to remove and readd the phone with no luck. Works fine on other phones.
    12-21-2016 03:38 PM
  2. B. Diddy's Avatar
    Does it depend on the phone's position? Bluetooth reception can be blocked by water, which means your body or a big bottle of water might actually cause some interference if they're in the right position.
    12-21-2016 10:31 PM
  3. Thomas Gruver's Avatar
    Nope.
    12-23-2016 02:55 PM
  4. B. Diddy's Avatar
    Did this start happening soon after a system update to the phone?
    12-23-2016 03:33 PM
  1. Why am I having pop up ads on my lock screen?
    Last Post: 01-31-2017, 05:30 PM
  2. can't send video through whatsapp on HTC 10
    By Danielmdmj in forum HTC 10
    Last Post: 01-06-2017, 10:27 AM
  3. Replies: 1
    Last Post: 12-21-2016, 03:29 PM
  4. How to fix a touchscreen that doesn't work on a Samsung J3
    Last Post: 12-21-2016, 03:14 PM
  5. m3u play lists no longer show up on Google Play Music - S7
    Last Post: 12-21-2016, 02:47 PM
