1. rdef's Avatar
    I have an s7 and just recently purchased an s7 edge. I'm noticing the lock screen behavior is different between the two, and I can't figure out why.
    I have my s7 flat set to lock after 10 minutes with a PIN. If I turn off the screen (with the power button) and turn the screen back on before 10 minutes (with either the home button or the power button), I am presented with the lock screen and notifications. I then have to swipe up if I want to get into the home screen.
    On the s7 edge, with the same settings, with the screen off when I press the home button or power button before 10 minutes, it goes directly to the home screen, skipping the lock screen and notifications.
    Is there a way to make the edge behave like the flat model?
    Thanks.
    12-23-2016 04:00 PM
  2. chanchan05's Avatar
    Settings>lock screen and security >secure lock settings>lock instantly with power key.
    12-23-2016 04:48 PM
  3. rdef's Avatar
    Thanks, but I don't want it to lock instantly. As mentioned, my s7 is set to lock in 10 minutes.
    12-23-2016 07:07 PM
  4. SamCarterX302's Avatar
    I'm confused, didn't you say you wanted your Edge to lock with the power button like your flat does?
    12-23-2016 08:49 PM
  5. rdef's Avatar
    Copied from my original post:
    Restated differently, on the s7 when you turn on the screen with the home button or power button *before* the lock timeout (in my case in less than 10 minutes), you are presented with the lock screen but the phone is not fully locked. All you have to do is then swipe up (without entering the PIN) if you want to see the home screen.
    The advantage of this behavior is that you can hit the power button or home button and see all your notifications. Additionally, the phone is not locked, so you don't have to enter a PIN if you want to act on a notification or do something else with the device.
    On the s7 edge, if goes right to the home screen when you click power or home. On the edge the only way you can have the notifications show on power or home click is if you set the phone to lock immediately. I don't want the phone to fully lock immediately.
    Make sense?
    12-23-2016 09:36 PM
  6. chanchan05's Avatar
    I sort of got it now. But I don't know how to do what you want.
    12-23-2016 09:37 PM
  7. SamCarterX302's Avatar
    Set the Edge's Screen lock type to Swipe. That should do what you want.
    Actually, never mind. I see what you mean.
    12-26-2016 01:55 AM
  1. Replies: 13
    Last Post: 07-14-2017, 02:09 PM
  2. Asus Google Nexus 7- flickering bands across entire screen
    By jon-M in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-30-2016, 07:23 AM
  3. lock screen changing
    By Stalonage in forum Honor 8
    Last Post: 12-24-2016, 03:15 PM
  4. it wont shut down it frozen on main screen
    Last Post: 12-23-2016, 04:53 PM
  5. Looking for shell/holster combo for S7 edge which supports USB and headphone ports.
    By atomarchio in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 12-23-2016, 02:20 PM
