1. Wrthgdrver710's Avatar
    I just got my s7 edge and the battery is not lasting as long as I feel like it should be. I've heard people that go 12-24 hours on a single charge and that just isn't happening with mine. I left it off the charger for a night and the battery dropped by 15%! As I'm using the phone I see the battery drop before my eyes.
    I've wiped the cache, done a factory reset, disabled a bunch of draining options but nothing seems to help. I'm considering returning it for another s7 edge but figured I would see if this is normal for the phone first.
    First time posting so if I'm missing anything please let me know.
    Here's a screenshot of gsam
    http://imgur.com/w3yeyV7
    12-23-2016 10:37 PM
  2. ThrottleJohnny's Avatar
    If you just got the phone, let it charge a few cycles. My battery got stronger after a few full charges. Also, check your signal strength
    12-23-2016 10:46 PM
  3. parth00790's Avatar
    may be you need to calibrate battery .
    for this just drain out your battery completely and change it while turned off . do this two three times and then done
    12-24-2016 01:50 AM
  4. bandofbrothers2112's Avatar
    I'd suggest to not let the battery drop below 20/10%.
    They don't tend to like draining all the way down.
    12-24-2016 02:28 AM
  5. parth00790's Avatar
    bro for recalibration of battery it must be done once atleast .
    calibration issues are common in Android gadgets dont worry it will not create any problem
    12-24-2016 02:49 AM
  6. parth00790's Avatar
    i think this is calibration issue .i have gone through samez😂😂
    12-24-2016 02:51 AM
  7. parth00790's Avatar
    if there are irregular patterns in battery drop or charge then possibilities are there of bettery stats issues . so calibration is just repair ing this
    12-24-2016 02:54 AM
  8. parth00790's Avatar
    let me know what happens after recalibration
    12-24-2016 02:58 AM
  9. jejb's Avatar
    Not normal for mine. I left mine unplugged the 2nd night I had it, after charging to 100%. It lost 3% in 7 hours, and that's been consistently the case every time I've tested it that way. I run BT and Wifi all the time, location off, wifi searching off, I don't use any social media apps on my phone like FB, etc. Stock phone, no disabler, no greenify, no doze apps, run TW. VERY impressed with the battery life on mine.
    One thing to try is dumping your cache. Settings->Storage. Touch cache and confirm delete. You may want to dump the cache in the recovery mode, too (hold down the vol up, home and power buttons at the same time from a powered off phone to get to recovery).
    12-24-2016 06:36 AM
  1. Replies: 3
    Last Post: 01-24-2017, 11:38 PM
  2. Will leaving data on all the time use more battery
    By android jack in forum Ask a Question
    Last Post: 01-06-2017, 04:02 AM
  3. S7 versus S7 Edge lock screen behavior
    By rdef in forum Samsung Galaxy S7 edge
    Last Post: 12-26-2016, 01:55 AM
  4. VZW S7 Edge Update
    By tallyboy29 in forum Samsung Galaxy S7 edge
    Last Post: 12-23-2016, 10:06 PM
  5. why is my contaCT muted on my Galaxy s7?
    Last Post: 12-23-2016, 07:08 PM
