1. Florida Guy's Avatar
    When I click settings, battery, then more, then optimize battery usage, it says "apps not optimized" so I click on "all apps" and it shows them all on, but when I go back into settings to check, they are all turned off. I can't get my phone to hold the setting.
    I just had a thought... is it actually staying on, then when I go back into app it automatically turns feature off?
    On another front: my always on gets brighter and darker while sitting in a room without any light change to cause display to brighten or darken. This happens on a constant basis. Is this normal? I don't think so, but I've only had the phone a few days.
    Thanks for any advice.
    12-25-2016 02:50 PM
  2. Tsepz_GP's Avatar
    WRT Your 1st Question:
    When you click 'All Apps', all those Apps being Optimised already, what the point of it is, is to turn Off the optimising.
    In other words you are meant to go to 'All Apps' and turn Off the ones you don't want to be Optimised, these will then move to the 'Apps Not Optimised' list.
    Hope that helps.
    WRT Your 2nd Question:
    That is indeed very odd, and could be due to a faulty Light Sensor OR a faulty Display. One of them is causing the dimming and brightening.
    Out of curiosity do you have any apps installed that may conflict with the phones Stand By state? Maybe a launcher or app like Greenify?
    EDIT: Another question, in your Display settings do you have Screen Mode set to Adaptive Display? That may also be at fault.
    12-25-2016 06:11 PM
  3. Florida Guy's Avatar
    To answer your last question first... It was set to adaptive display and I just changed it to basic. Is that the right move?
    No new apps loaded, and no Greenify.
    I want optimising on for all apps, but when I turned on that feature and went back to look at it, it was not on. I think it's okay if I don't toggle back to it.
    Thanks for the help.
    12-25-2016 06:42 PM
  4. ZOMMBIE1's Avatar
    If your on Verizon it's blocked from working. Good ol' Verizon
    12-25-2016 07:45 PM
  5. Florida Guy's Avatar
    Yes, I'm on Verizon.
    Thanks for the info. I am just trying to preserve battery life.
    12-26-2016 02:29 PM
  6. Tsepz_GP's Avatar
    Oh crap! That explains a lot.
    Yeah,Verizon has retarded the S7's Power Management Menus, they are not like what the rest of us have.
    12-26-2016 06:18 PM
  1. battery issues
    By Jar0425 in forum Google Pixel & Pixel XL
    Last Post: 12-28-2016, 11:32 AM
  2. Cant set up yahoo mail on lg v20
    Last Post: 12-25-2016, 05:34 PM
  3. Replies: 1
    Last Post: 12-25-2016, 05:00 PM
  4. Replies: 0
    Last Post: 12-25-2016, 02:08 PM
  5. Can I individually name pages in a pdf on play books?
    Last Post: 12-25-2016, 12:19 PM
