1. Misterb's Avatar
    It gets old having a pop up every time I'm at a store or restaurant. I've done some searching, and the closest I can find is to turn Questions about Places off in Google Maps, but I have and it's still happening.
    12-26-2016 01:51 PM
  2. Wobblin30's Avatar
    Go into settings in Google Now. You can manage anything within your feed from there.
    12-26-2016 08:05 PM
  3. Misterb's Avatar
    Awesome. Thanks. I will try it out and see if that fixes it
    adayoff likes this.
    12-26-2016 08:54 PM
  4. anon(5719825)'s Avatar
    I had to do the same thing. It was always asking me to review the place I work at every single day, sometimes 2-3 times per day.
    12-27-2016 12:11 AM
  5. Snareman's Avatar
    Apparently if you review enough or post enough pics of places you can get some slight rewards. The only one I saw I was vaguely interested in was 50 photos/reviews gets you 100gb of google drive for a year. At least I think that's what it was.
    12-27-2016 02:49 AM
  6. Misterb's Avatar
    What a nuisance. Can't believe they didn't think of that scenario
    12-27-2016 06:38 AM
  7. N4Newbie's Avatar
    Actually, I am pretty certain this is part of Google Maps, not Google Now.
    Open Maps, tap the hamburger menu at top left, tap Settings, tap Notifications, tap Your Contributions.
    adayoff, Alanhd, shaleem and 1 others like this.
    12-27-2016 05:50 PM
  8. torbach1's Avatar
    That's correct, it is a Google Maps thing. It also doesn't start on its own. It would have asked you at some point if you want to provide additional information about places you visit.
    shaleem likes this.
    12-27-2016 07:49 PM
  9. Misterb's Avatar
    Like I said originally, I turned off the option in Google maps, but it was still doing it. This other fix seems to have taken care of it though. It didn't bug me at any if the stores or restaurants I went to today
    12-28-2016 12:05 AM
  10. N4Newbie's Avatar
    Very interesting. I wonder if it is part of *both* Google Maps *and* Google Now?
    12-28-2016 07:21 AM
  11. jdballard's Avatar
    Unfortunately, if you've never used Google Maps, you don't really know what that means. Good to know how to turn it off!
    12-28-2016 09:48 AM
  12. shaleem's Avatar
    Thank you, thank you, thank you! It was driving me crazy!
    adayoff likes this.
    12-28-2016 10:02 AM
  13. Pete1389's Avatar
    I have ALL the settings in Your Contributions turned off in the Maps app and I am still receiving these ultra-annoying notifications.
    04-04-2017 01:28 PM
  14. Pete1389's Avatar
    I think I figured it out, it's in:
    Google Now > Settings > Notifications > Your Feed > Places
    LineKill, happy0506 and zapjb like this.
    04-04-2017 01:32 PM
  15. LineKill's Avatar
    Thank you for posting this. Both Google Maps and Google now can provide these types of notifications.
    It can be a real head scratcher. Hopefully this will help minimize future head scratching🤕
    04-04-2017 01:45 PM
  16. rightnitro's Avatar
    I don't have Google Now on my Galaxy S5. Is there something else I should do other than turn all the Maps Contributions off?
    09-12-2017 12:48 PM
  17. anon(238680)'s Avatar
    That should be enough, but you might check your online Google account settings also.
    09-12-2017 01:00 PM
  18. chanchan05's Avatar
    Yes you do. It's not a separate app. It's part of the built in Google app (shows up on long press of the home button, unless you set that up to be S Voice). The only way for you to not have Google Now is if you deliberately uninstalled the Google app.
    Laura Knotek and zapjb like this.
    09-13-2017 02:21 AM
  19. OnyxReality's Avatar
    Voilà... you're welcome.
    Google Maps> Settings> Notifications> Your contributions> Questions about places
    09-15-2017 12:35 AM
  20. tjjharris's Avatar
    Make the entire world a better place for yourself and everyone around you when you turn off notifications that do not truly serve your intentions in your life. Simplify, becalm, re-JOYce.
    1. Open "Settings" on your Android device.
    2. Scroll down to Device > Notifications.
    3. Scroll down to and select "Maps".
    4. When it loads, touch/open the "gear" icon - it will open the settings for "Maps".
    5. There, you may select from the plethora of notification settings for Google Maps. You will likely find more things to turn off (or on) there, but the one you seek was found on my phone at the top: "Questions about Places". You may also want to also toggle "off" several of the other requests for your contributions, e.g. "Adding your photos".
    There are several others which I found equally intrusive as the insistence that you help others, rate your location, rate your restaurant, etc.
    My own editorial justification:
    So much of life's already pressing anxieties seem to me driven by such unnecessary complexities as this, like deleting incoming spam malware in the form of faux ads that click-bait you to go-to, buy-from, or unsubscribe-from and thereby more than likely infect your system with ransomware. (MALware + AD spam I refer to as "Malade-ware" or "maladyware").
    Making life simpler at every turn allows Joy, Love, Power, to replace annoyance, which is ultimately low-level fear at its root, clinging to wanting things to be other than they are with the sense of powerlessness from the tech-world's bombardment of annoyances from everywhere; never ending, that we can't make the annoyance stop. No peace = no Joy = No true happiness. This is ultimately the killer of a mindset and "heartset" of peace and love which can only be truly experienced in the moment -- now -- and is constantly displaced by the low-level anger that such annoyances bring, and its root -- fear. Love and fear cannot coexist...they are opposites. One is anchored in past and future, the other in your true self when you are present.
    12-25-2017 12:37 PM
  21. zapjb's Avatar
    Thanks all. I think it's gone. Again much appreciated.
    01-06-2018 02:01 PM
  22. toad15's Avatar
    What's annoying is when you get invited to rate places you've never been to just stuck in traffic outside.
    08-20-2018 05:21 PM
  1. Replies: 1
    Last Post: 01-09-2017, 07:27 AM
  2. Best app to auto-disable/enable WiFi by location or router?
    By dhinged in forum General Help and How To
    Last Post: 12-26-2016, 08:29 PM
  3. Geting Ok Google to work on Note 4 from any screen?
    By michail71 in forum Ask a Question
    Last Post: 12-26-2016, 08:20 PM
  4. what to do wheni change my memery card
    Last Post: 12-26-2016, 03:53 PM
  5. receive group texts OK, cannot reply to them
    By Steve USA in forum LG G3
    Last Post: 12-26-2016, 01:44 PM
