1. Florida Guy's Avatar
    I let battery drain down to 11% before laying on fast charging pad. It said it would take 2 hours and 11 minutes to full charge,
    but it took 3:35, almost an additional 90 minutes. Is this normal? I've only had the phone less than a week, and this was the
    first time I drained it down so low. It's also not lasting long on a charge. I hardly used it and it drained to 11% in less than 2 days.
    Is battery life supposed to improve after a few cycles? I am still within 2 week period where I can return it to Costco for another one.
    My Note5 battery lasted much longer than this larger one. Makes no sense.
    BTW... phone was turned off during charging.
    Thanks
    12-26-2016 02:37 PM
  2. NexusGirlX's Avatar
    It happens sometimes on my Samsung charging stand. Normally it takes about 2hrs or so but sometimes it can take longer.
    On my Note 5, it usually takes about 30 minutes less but that's because it has a smaller battery. Wireless charging will always take more time then wired will.
    I usually get anywhere between 2-4hrs and 1-2 days standby on my Edge. This is normal for me. I barely get an hour of usage on my Note 5 with one dsy standby.
    12-26-2016 02:50 PM
  3. Johnston212's Avatar
    What kind of wall adapter are you using? Anker has some fast qi chargers and their info indicates that you need a QC 3.0 adapter
    12-28-2016 12:17 PM
  4. Florida Guy's Avatar
    I am using the adapter that came with the pad. I am using the factory Samsung QC pad.
    12-29-2016 02:12 PM
  1. Replies: 1
    Last Post: 01-09-2017, 07:27 AM
  2. Replies: 2
    Last Post: 12-26-2016, 05:48 PM
  3. my mobile's charging is fluctuating
    Last Post: 12-26-2016, 04:56 PM
  4. Does fast charger ruins my battery?
    Last Post: 12-26-2016, 03:56 PM
  5. Battery want charge
    Last Post: 12-26-2016, 01:06 PM
