1. atomarchio's Avatar
    Recently purchased the S7 Edge.
    The USB cable it comes with provides "fast charging" at least when plugged it sometimes indicates that.
    Would it be possible to purchase another "fast charging" similar to the one that came with the S7 edge from another vendor? If so, can someone suggest brand and/or model number?
    Please let me know. Thanks.
    12-28-2016 07:57 AM
  2. chanchan05's Avatar
    No. Samsung uses a proprietary fast charging plug. It's not the cable that gives the fast charging, but the charging block. You can use any good quality cable for fast charging, provided you use the Samsung charging head given to you.
    Dngrsone likes this.
    12-28-2016 08:12 AM
  3. atomarchio's Avatar
    That's helpful to understand. Thanks.
    12-28-2016 08:35 AM
  4. Dngrsone's Avatar
    Keep an eye on Anker; they will likely come out with a compatible fast charger.
    Frankly, my S7E charges pretty darn fast off my 2a Anker chargers and batteries, and I see no need to use the one that came with the phone.
    12-28-2016 09:43 AM
  5. chanchan05's Avatar
    The built in one slices off only 20min in total charging time when used in fast charge mode. And fast charge mode only works when below 60%.
    12-28-2016 09:48 AM
  6. atomarchio's Avatar
    Based on your suggestion, I am trying to figure out which cable to order in order to charge my S7 Edge with the existing Samsung Block.
    Is this the correct spec?
    "USB 2.0 Hi-Speed A to Micro-B Coiled Cable (M/M), 3 ft"
    It looks correct but I'd like to confirm.
    12-29-2016 07:24 AM
  7. joe_fresh's Avatar
    Not true, Mine said rapid charging and my phone is at 86%.
    12-29-2016 02:59 PM
  8. jaltman's Avatar
    Any Qualcomm 2.0 or 3.0 compatible charging block will fast charge our phones. I have a 6 port Cheotech with 2 ports that are Qualcomm 2.0 and those ports fast charge just fine.
    12-29-2016 04:10 PM
  9. chanchan05's Avatar
    I know what I'm talking about. The phone still says it's Fast Charging. But it's not that fast anymore. Once it hits 60%, charging has slowed down to not destroy the battery. It takes considerably longer to charge from 90-100%, as compared to 0-10%. The S7 uses tech based off qualcomm quick charge 2.0.
    https://www.google.com.ph/amp/www.ub...ndroid-samsung
    The S6 and S7 share the same quick charge tech (2.0), with the only difference being that the S6 has smaller batteries, hence charges faster. Here is a test where they timed the S6 charging.
    http://www.droid-life.com/2015/03/31...what-happened/
    The relevant part is:
    "Here is the timing breakdown during our charge:
    Started at 5%
    5 minutes in – 14%
    15 minutes in – 32%
    40 minutes in – 76%
    50 minutes in – 88%
    72 minutes in – 100%"
    0-14% in 5 minutes. 88-100% (12%) in 12 minutes. That's more than twice as slow.
    This technology is also one of the reasons why Quick Charging was initially one of the suspects for the Note7 explosions, with people wondering if Samsung made a mistake in implementation, making the battery charge too fast to 100% causing it to explode.
    12-29-2016 05:30 PM
  10. Almeuit's Avatar
    Cleaned up some posts. If you want to be helpful / contribute to the conversation then by all means go ahead. If you want to just be toxic please take it elsewhere. Thanks.
    12-30-2016 12:44 PM
  11. atomarchio's Avatar
    Does anyone know if the micro B connector is compatible with S7 edge?
    12-30-2016 01:21 PM
  12. Dngrsone's Avatar
    Yes, the Edge uses a micro B
    12-30-2016 02:16 PM
  13. atomarchio's Avatar
    Got it. Thank you.
    12-30-2016 04:33 PM
  1. Replies: 2
    Last Post: 09-04-2018, 04:32 PM
  2. How can i get google apps working on Chinese samsung C7?
    Last Post: 01-12-2017, 05:50 AM
  3. I can't delete music on my xperia!
    By magnuslennon in forum Ask a Question
    Last Post: 12-28-2016, 08:30 AM
  4. Always on display
    By Stephanie1994 in forum Samsung Galaxy S7 edge
    Last Post: 12-28-2016, 04:46 AM
  5. black background for s7 edge same as s4 how do i change it
    Last Post: 12-28-2016, 04:34 AM
