1. Rooogern's Avatar
    Is anyone else missing the LTE setting under network on their Galaxy S7 edge? I have compared my phone With 2 others. We have the same service provider, and the last firmware update. My phone does not activate LTE automatically like the two other phones and the LTE setting is missing. I put my sim-card in the other phone an then i have LTE, but not on my phone. Does anyone have a solution for this?
    12-30-2016 08:28 PM
  2. Staffie85's Avatar
    That's unusual, have you tried a network reset or factory reset? If that doesn't help you can always try connecting it to your computer and using Kies or Smart Switch to reinstall the firmware and settings as that should definitely fix the problem.
    Hope it helps
    12-31-2016 06:36 AM
  3. Rooogern's Avatar
    Thank you for answering. I have tried factory reset and installed firmware with smart switch, but still no LTE or LTE setting on my phone. I have contacted Samsung support so i hope it can be solved.
    01-01-2017 06:52 PM
  4. dlgus's Avatar
    I hadn't even noticed that, but I don't have it either. Haven't noticed a difference...does it matter?
    01-03-2017 10:38 AM
  5. dlgus's Avatar
    UPDATE: this really had me stumped...I kept looking at my 4G, and noticed 'something' next to it. Had to get out my magnifying glass, and there it was LTE ...old eyes lol
    01-04-2017 05:22 AM
  1. Professional Underwater Housing for Samsung S7? Rated to 100 feet or more
    By Apothecia in forum Samsung Galaxy S7 Cases & Accessories
    Last Post: 09-06-2017, 06:49 PM
  2. Can my Samsung Galaxy S5 G900A (AT&T) be rooted?
    By tony19950725 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 01-03-2017, 03:06 AM
  3. Replies: 2
    Last Post: 12-30-2016, 11:05 PM
  4. Is Fast Charging Wireless available for Galaxy Note Edge
    Last Post: 12-30-2016, 04:57 PM
  5. Why my samsung galaxy tab a will not vibrate or flash
    Last Post: 12-30-2016, 03:43 PM
