1. android jack's Avatar
    My previous phone was an HTC phone and HTC has a theme store with so many themes that I could search for anything and it be there. Now that I have samsung it seems I struck out on the theme front. I search and nothing or something that has little to do with what I want. Is there any other place I can get themes?
    01-01-2017 03:42 PM
  2. anon(9408097)'s Avatar
    Try searching the words
    Black
    Material
    Material design
    Dark
    Touchwiz
    Flat material
    You will find plenty of decent ones.
    And no I don't think there's any other place to get themes for Samsung.
    01-01-2017 04:54 PM
  1. Phone battery drain caused by Samsung Gear Manager app
    By yoggee in forum Samsung Gear S3
    Last Post: 01-03-2017, 10:30 AM
  2. Need someone with the Android 7 update and can run terminal commands
    By Jerry Hildenbrand in forum OnePlus 3 & 3T
    Last Post: 01-02-2017, 10:14 PM
  3. Can I safely delete or disable the green guys in my apps list
    Last Post: 01-01-2017, 03:10 PM
  4. need a fast charger for my samsung note 5
    Last Post: 01-01-2017, 02:49 PM
  5. Why is my google play store not working
    Last Post: 01-01-2017, 02:44 PM
