1. Rumblee1's Avatar
    I downloaded Android file manager on my macbook air and it still did not recognize my S7 edge. What's up
    01-01-2017 08:30 PM
  2. hallux's Avatar
    You installed Android File Transfer?
    Did you also pull down your notification shade and change the "mode" for your phone? You need to change from charge mode to one that allows for file transfer. This notification only shows up once the phone is plugged in.
    See these screenshots from my Nexus 6P:
    Look at the bottom of my notification shade in the first image, tap that and you get the dialog in the next image.
    01-01-2017 09:12 PM
  3. thecomicbookandme's Avatar
    Android file transfer hasn't been updated in years. Try Samsung Smart Switch. You can find it in the Playstore.
    01-02-2017 04:38 AM
  4. Rumblee1's Avatar
    I believe I've got that on my phone. Does it also have to be installed on the Mac?
    01-02-2017 09:45 AM
  5. Rumblee1's Avatar
    I'll try it too. Your screen shot didn't show up.
    01-02-2017 09:47 AM
  6. hallux's Avatar
    Odd, they show up for me on a computer browser but not in the AC app.
    01-02-2017 11:04 AM
  7. WalkingHorse's Avatar
    Yes. You need to install it on your mac. Works great for backing up your phone as well as transferring your existing setup to a new phone.
    01-03-2017 09:44 AM
  1. USB connect to Mac?
    By CBmanJWS in forum Moto G
    Last Post: 02-24-2017, 07:14 PM
  2. How do you update a ZUK Z2 using a Mac
    Last Post: 01-01-2017, 01:56 PM
  3. Replies: 1
    Last Post: 12-31-2016, 05:39 PM
  4. Replies: 1
    Last Post: 12-31-2016, 02:02 PM
  5. auto syncing to the nexus 7?
    Last Post: 12-30-2016, 02:52 AM
