01-04-2017 05:02 PM
36 12
tools
  1. monsieurms's Avatar
    Looks like it's going to be pretty dang solid.
    Been hearing from beta testers that it seems to improve daily performance and helps with battery life.
    So far, the battery life is so vastly superior to Marshmallow...of course, I have to admit, it's not quite an A- to A comparison as I'm used different phones on those OS versions.
    KPMcClave likes this.
    01-03-2017 10:27 AM
  2. Epwhamilton's Avatar
    I had a update this morning. It seemed a pretty major install process though I think it was only 300mb. Can't see anything about it in the software stats like security update etc.
    01-03-2017 01:11 PM
  3. lammy8's Avatar
    Just checked and I have this. Is your android version still 6.0.1?
    01-03-2017 04:42 PM
  4. tennislvr8's Avatar
    I know this is silly but this was one of the best features for me. Non white notification icons in the notification bar for third party text and email apps, will this make a comeback with nougat? TIA
    01-03-2017 10:14 PM
  5. Epwhamilton's Avatar
    Yes, it's weird. Nothing seems to have changed!
    01-04-2017 12:57 AM
  6. NexusGirlX's Avatar
    Whats the Security patch level? Mine says December 1st although I got an update around 300MB christmas week. I am on the Nougat beta.
    Non Nougat Edge shows November 1 security patch level and I'm on T-Mobile.
    01-04-2017 03:21 AM
  7. dlgus's Avatar
    Verizon users are getting comfy on the couch and will be expecting it by March
    Well that sucks!
    01-04-2017 05:10 AM
  8. Nakrohtap's Avatar
    When I first starting running beta about a month ago, I was on December security patch on MM. Once on beta, I was back to November shortly. I am on T-mobile as well.
    01-04-2017 05:35 AM
  9. Epwhamilton's Avatar
    Security patch is dated 1st December. Baseband is BPK6 but as to whether that makes any difference I'm not sure.
    When I first starting running beta about a month ago, I was on December security patch on MM. Once on beta, I was back to November shortly. I am on two as well.
    01-04-2017 11:53 AM
  10. Epwhamilton's Avatar
    Android Authority are reporting that Baseband Build G935FXXU1DPLR is receiving Nougat as part of a soak test. Wish that was me!
    01-04-2017 01:05 PM
  11. lammy8's Avatar
    Yeah it was the December patch, quite large though.
    One thing I've noticed so far, when you take the device off charge the screen no longer wakes up.
    01-04-2017 05:02 PM
36 12
  1. Quick question about Pokedex...
    By DaBeard in forum Pokemon Go
    Last Post: 01-13-2017, 11:38 AM
  2. Xposed for nougat
    By DudeThatsErin in forum Android 7.0 Nougat
    Last Post: 01-06-2017, 12:26 PM
  3. Nougat update from ATT
    By athomas917 in forum AT&T
    Last Post: 01-04-2017, 01:13 PM
  4. concerned about radiation in Samsung Galaxy S7 Edge
    Last Post: 12-31-2016, 07:14 PM
  5. concerned about radiation SAR for galaxy edge 7
    By is1 in forum General News & Discussion
    Last Post: 12-31-2016, 07:11 PM
