Prime Day deal: Save $200 on the Samsung Galaxy S21
  1. Noah Armstrong's Avatar
    Hello, I have an AT&T s7e that I pre-ordered. I've recently been having terrible battery life. Not sure what to do at this point. These are the stats of my phone after being on standby almost the whole day. I've also been using greenify
    01-05-2017 02:14 PM
  2. B. Diddy's Avatar
    Sorry, it's hard to see that image clearly on the desktop forum site. Can you post screenshots this way? http://forums.androidcentral.com/gen...d-central.html
    Also, in general, these are the screenshots that can be helpful:
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    (I can just make out on your screenshot that your Cell Standby category is somewhat high, so that suggests your cell signal is generally poor.)
    01-05-2017 03:54 PM
  3. Noah Armstrong's Avatar
    Hello, I have the screenshot you requested. I've had almost perfect service all night, so no idea why it's the top user. Also, every six seconds, I get the 4glte icon flashing next to my WiFi icon. Any idea what this is doing?
    01-05-2017 09:31 PM
  4. Noah Armstrong's Avatar
    More
    01-05-2017 09:35 PM
  5. Noah Armstrong's Avatar
    Another one
    01-05-2017 09:36 PM
  6. Noah Armstrong's Avatar
    Another
    01-05-2017 09:37 PM
  7. Noah Armstrong's Avatar
    Overview
    01-05-2017 09:37 PM
  8. Noah Armstrong's Avatar
    GSam overview
    01-05-2017 09:37 PM
  9. Noah Armstrong's Avatar
    Apps
    01-05-2017 09:38 PM
  10. Noah Armstrong's Avatar
    GSam wifi
    01-05-2017 09:38 PM
  11. B. Diddy's Avatar
    I'm not sure why you're getting that. Usually, high Cell Standby battery use means poor signal. Find the graph in GSam that shows your Cell Signal Strength, and show us what it looks like over the span of an entire battery charge.
    It also seems strange to me that GSam is reporting that wi-fi is accounting for almost half of your battery usage. Do you have wi-fi calling turned on?
    Did you start using Greenify before this all started, or after?
    01-06-2017 11:28 PM
  12. nizmoz's Avatar
    I'm also getting high battery usage on my s7 edge with AT&T. It didn't use too now it's really bad. It didn't even fully charge after a full night either on the Samsung Charger!
    Attached Thumbnails Bad battery problems - help!-screenshot_20170108-102855.jpg   Bad battery problems - help!-screenshot_20170108-102845.jpg
    01-08-2017 10:30 AM
  13. o4liberty's Avatar
    I purchased PK package disabler from the play store for .99 and it improved my battery life by 50℅. Any high end Android device I have ever owned never had good battery life you need to tweak settings and disable bloatware to get any decent battery life IMO.
    01-08-2017 11:04 AM
  14. nizmoz's Avatar
    Not finding that app in the store. Okay, maybe you mean BK?
    01-08-2017 11:12 AM
  15. jaltman's Avatar
    Have you tried doing a factory reset?
    01-08-2017 02:47 PM
  16. o4liberty's Avatar
    Yes BK sorry
    01-08-2017 03:07 PM
  17. o4liberty's Avatar
    It will disable all the useless bloatware on your edge worked great for me and no need to root.
    01-08-2017 03:08 PM
  18. nizmoz's Avatar
    My S7 Edge got awesome battery life today thanks to this app and wiping the cache.
    Thank you!
    Attached Thumbnails Bad battery problems - help!-screenshot_20170109-192653.jpg
    01-09-2017 07:28 PM
  19. Floridadomer's Avatar
    I am on AT&T also and my battery life started getting really bad about three days ago also.
    01-11-2017 03:07 PM
  1. Help:. my Huawei watch puts my Nexus 6P on mute
    By neodoc427 in forum Huawei Watch
    Last Post: 01-05-2017, 11:42 PM
  2. OP3 Battery Drain 3.2.8
    Last Post: 01-05-2017, 12:38 PM
  3. Marshmallow upgrade ringer notification volume problems
    Last Post: 01-05-2017, 12:21 PM
  4. Battery Running Down Quickly
    Last Post: 01-05-2017, 11:50 AM
  5. Does turbocharging damage the battery?
    Last Post: 01-05-2017, 11:27 AM
