How do I create a blank application folder on my home screen?
Printable View
To create a folder, you have to first drag one app shortcut onto another. But if you remove the last app from a folder, I believe it disappears -- I'm not sure if you can have an empty folder.
I have apps to put in a folder. I need to create a folder like the one already created for Google.
Drag an app over on top of another app and drop it.
Thanks so much. It works fine.
