1. spinachie's Avatar
    Just buying an s7 edge and after looking online it seems no screen protectors are compatible with a case as well.
    Can anyone recommend what type of screen protectors to get with a silicone case? The glass ones seem like a definite no as the case won't bit around the edges with the protector on.
    The TPU ones look like they will be crazy difficult to add with the curved edges.
    What is everyone doing here and what would you advise? I drop my phone on occasion so need the silicone and the phone is always in my pocket so keys etc can scratch it.
    Please help
    01-06-2017 02:01 AM
  2. N7AS's Avatar
    I use an OtterBox Defender on my S7 Edge. Has built in screen protector that others say is not too responsive, but I think it's fine for me. The case even works with the Samsung Wireless Charger.
    Fit24 likes this.
    01-06-2017 02:12 AM
  3. Dngrsone's Avatar
    I'm using a Unicorn Beetle Pro case with Armorsuit screen protector. You do have to get the protector lined up perfectly, or the case will peel up an edge.
    Previously, I've used Otter box Defender on my Galaxy devices, and generally have to replace it every eight months or so: the case protects my device fabulously, the built-in screen protector does its job well, but I do drop my phone on a semi-regular basis and I'll break the holster or occasionally the case itself, and the rubberized skin of the case stretches out over time.
    I too heard about the sensitivity issues with the Edge variant Otterboxen and I can understand the problem Otterbox is having trying to cover that area, which is why I went with the Unicorn case.
    01-06-2017 06:45 AM
  4. spinachie's Avatar
    Thanks for the replies. I have bought a relatively cheap silicone case from JETech, which has good reviews.
    I am going into a phone store today where they will add the film screen protector for me directly, so will let you know what happens.
    The Otter looks good, but its expensive and the concerns over sensitivity worry me.
    Dngrsone likes this.
    01-06-2017 08:03 AM
  5. parthtc09's Avatar
    Tried a screen protector off amazon with no luck, the unicorn beetle case is great but I upgraded to the speck military grade clear case, it's sleek and sturdy.
    01-06-2017 10:15 AM
  6. thunderbomb's Avatar
    I have a bodyguardz contour HD and use an Otterbox commuter case and there has been no issue of peel up and I've had it on for about 2 months now.
    sweetypie31 likes this.
    01-07-2017 08:46 AM
  7. Lepa79's Avatar
    Spigen rugged case and Armorsuit. Works perfect.
    Spigen Rugged Armor Galaxy S7 Edge Case with Resilient Shock Absorption and Carbon Fiber Design for Samsung Galaxy S7 Edge 2016 - Black https://www.amazon.com/dp/B01A7IDHOU...cUvbUpU5634676
    Armorsuit MilitaryShield Anti-Bubble Ultra HD Screen Protector for Samsung Galaxy S7 Edge - Clear https://www.amazon.com/dp/B01ACXSKAG...cUvbUpU5634676
    01-07-2017 09:06 AM
  8. spinachie's Avatar
    So the guy in store added one on for me and there is slight peeling on the edges so far.
    What I might do is wait for the edges to peel more and then buy another protector and trim the edges slightly so it doesn't peel. As long as the screen is protected I'll be happy
    01-08-2017 08:32 AM
  9. sweetypie31's Avatar
    I have an HD contour for screen protector and OtterBox symmetry. Both work perfectly.
    01-08-2017 09:02 AM
  10. spinachie's Avatar
    Dawn the armorsuit one looks like it's been specially developed for cases can't get it in the UK
    01-08-2017 03:54 PM
  11. o4liberty's Avatar
    I use OtterBox symmetry case with insurance for cracked screen never found a decent screen protector.
    01-08-2017 05:50 PM
  12. Blues Fan's Avatar
    Also it's cloudy too for some people. My Defender luckily has a very clear screen protector. I think that might have been an early production issue.
    Otterbox has always had trash screen protectors. The S7 Edge one actually fits flush due to being thicker. However I don't understand why they can't perfect it. I ripped the protector off my V20 it was so terrible.
    For example the Supcase Unicorn Beetle always has great screen protectors that fit tight to the screen and clear and that case is the fraction of the Defender cost.
    01-09-2017 12:22 PM
  13. Dngrsone's Avatar
    I never had problems with the screen protector on the Defender series... I use them on Galaxy Tab 2 and Tab 4 as well as S4...
    01-09-2017 02:20 PM
  14. Fit24's Avatar
    I'm using the OtterBox Defender. I like it primarily because it has a built in screen protector.
    01-09-2017 09:46 PM
  15. pontiac005's Avatar
    using a unicorn beetle pro and yootech screen protector. I also have a UAG, which I really like but the unicorn beetle pro gives better front and side protection.
    01-15-2017 12:42 AM
  1. Music players show albums with less songs
    By Ran Cohen1 in forum Android 6.0 Marshmallow
    Last Post: 01-07-2017, 08:44 AM
  2. Replies: 2
    Last Post: 01-06-2017, 06:51 AM
  3. Replies: 3
    Last Post: 01-06-2017, 03:57 AM
  4. How do I contact my HTC 530 with mhl
    Last Post: 01-06-2017, 03:02 AM
  5. problem with my smasung s7
    Last Post: 01-06-2017, 01:03 AM
