1. jmagid51's Avatar
    How can adjust the sensitivity of my touchscreen?
    01-06-2017 10:28 AM
  2. SpookDroid's Avatar
    Unfortunately you can't. Unlike previous models where you could boost sensitivity for use with gloves, the feature is no longer available (as the screen is already a tad more sensitive and can be used with thin gloves anyway). The only way to increase it now is by hacking the phone and messing with the hardware.
    01-06-2017 10:53 AM
  3. jmagid51's Avatar
    Thanks for the help. Was great on my Note4.
    01-06-2017 11:06 AM
  4. SpookDroid's Avatar
    Yeah, I know I think that was the only year they used that feature. I miss the 'finger hover' feature as well, and the hand-swipe gesture to scroll; I wish they'd kept those.
    01-06-2017 11:17 AM
  5. ThrottleJohnny's Avatar
    Yeah...People called all that stuff bloat, so they got rid of it.
    01-06-2017 11:25 AM
  6. Nakrohtap's Avatar
    When my first Note7 was a little unresponsive to touches sometimes, I tired this app. Most people says it helps. I didn't use it or play around with the settings enough to know for sure how effective it was. Worth a try.
    01-06-2017 12:06 PM
  7. jmagid51's Avatar
    https://uploads.tapatalk-cdn.com/2017...bc9ef3bbf6.jpg
    Just installed it, seems to work well.
    Thanks
    01-06-2017 01:52 PM
  1. Tablet touchscreen not responding to touch
    Last Post: 01-06-2017, 06:51 AM
  2. Replies: 0
    Last Post: 01-05-2017, 07:46 AM
  3. How to fix a touchscreen that doesn't work on a Samsung J3
    Last Post: 12-21-2016, 03:14 PM
  4. Nextbook NEXT7D12R - Touchscreen stops responding
    Last Post: 12-21-2016, 02:09 PM
  5. Nexus 4 touchscreen dead spot - what to do?
    By orreborre in forum Google Nexus 4
    Last Post: 12-21-2016, 02:07 PM
