1. Subhasis Pramanik's Avatar
    Hello All,
    I have new user of S7 Edge.
    I got few problems. I have checked for solution everywhere but not got any satisfactory result.
    1. I have log in with Samsung account and keep of automatic sync to Samsung cloud. But still data sync to Samsung Cloud automatically. It is using high data. I contacted with Samsung care. They said to log out and re login will solve the issue. But still it is not solved.
    2. Always call volume is in max. No matter how many times I change the level, it always go to max automatically.
    3. Auto brightness seams not working properly. While removing auto brightness, brightness level not restore to previous set level automatically as it was happening my previous mobile S3, S5.
    01-07-2017 11:31 PM
  2. B. Diddy's Avatar
    Try wiping the cache partition, which won't erase any personal data: https://support.t-mobile.com/docs/DOC-28028
    01-09-2017 12:31 AM
  1. problem with samsung note 5
    By mandieryan in forum Samsung Galaxy Note 5
    Last Post: 01-08-2017, 08:24 AM
  2. Notification problem?
    By FishMT in forum Samsung Galaxy S7
    Last Post: 01-07-2017, 10:28 PM
  3. Replies: 0
    Last Post: 01-07-2017, 06:48 PM
  4. looks like s7 nougat update soak test underway!
    By yubeie in forum Samsung Galaxy S7
    Last Post: 01-07-2017, 04:08 PM
  5. Can't get into whats app on galaxy s7
    Last Post: 01-07-2017, 01:14 PM
