Originally Posted by
sparksd I jumped from the Note 4 to the S7E and couldn't be happier with it. LTE reception performance is significantly better. Only regret is that I didn't change sooner (though my Sprint plan was a major factor). Of course you're going to see lots of issues on forums - that's just the nature of the beast. Every forum for every kind of device (smartphones, computers, tablets, cameras, etc) is loaded with post on issues. After reading them you feel as if every device out there is fatally flawed.
Exactly the same here
I had a Note 4, and was waiting for the Note 7, but after the whole debacle I went with the S7 Edge and could not be happier.
With the S7 Edge being the highest selling Android since it's launch its bound to have more complaints than any other Android.
The S7 Edge is up to this day the best all round Android smartphone, all its competitors are missing something it has, be it IP68 Water and Dust Resistance, or no 2K display, no MicroSD, or fall behind in Camera.
With the S7 Edge you get a full package:
Huge 3600mah battery with great battery life
2K SUPERAMOLED Display
MicroSD Support
The best Camera around
Compact design
IP68 Dust and Water Resistance
Feature packed UI
Great front facing Finger Print Scanner
Great VR support
