1. amyf27's Avatar
    OK, I have my S7 Edge through T-Mobile as my replacement device for the Note 7. The screen is too small so for now I have a new Nexus 6P as well that I got yesterday and it's turned into my primary phone. What I just discovered has thrilled me - I don't have to swap out my sim to use my S7Edge for Samsung Pay. All I do is create a hotspot on the 6P, connect the 7Edge to it, and Samsung Pay works great! Even redeemed my $20 visa rewards and used part of that on the edge to pay for something this afternoon .
    01-12-2017 01:12 PM
  2. SpookDroid's Avatar
    Yup, Samsung Pay works regardless of SIM card, and even works without a data connection (at least for cards already loaded). Using on 'offline' mode, however, only works for so long IIRC; the phone will eventually need a valid data connection (mobile or WiFi) to 'renew' the token.
    amyf27 likes this.
    01-12-2017 01:27 PM
  3. amyf27's Avatar
    Will likely upgrade the S7Edge to the new S8 or Note 8 when they're available
    SpookDroid likes this.
    01-12-2017 01:39 PM
  4. SpookDroid's Avatar
    Me too. I just really hope they come out with a 64GB version this time (and hopefully that'll be the base model).
    amyf27 likes this.
    01-12-2017 02:07 PM
  5. amyf27's Avatar
    The memory size doesn't concern me as much as the phone features, abilities, and appearance. But 64G standard would be nice.
    01-12-2017 02:17 PM
  1. Storage problem with lenovo A7000 and samsung evo 32 gb
    By Gagan Ramtani in forum Ask a Question
    Last Post: 01-20-2017, 04:41 AM
  2. Replies: 2
    Last Post: 01-12-2017, 03:37 PM
  3. Replies: 2
    Last Post: 01-12-2017, 03:17 PM
  4. Replies: 1
    Last Post: 01-12-2017, 02:23 PM
  5. Replies: 1
    Last Post: 01-12-2017, 02:05 PM
