I was helping a friend out with his s7 edge he recently bought off his other friend, and I get the screen that says that this device was reset and needs the previous gmail to verify and unlock this google lock.
So I went searching for ways, one was with turning on and off the hotspot at respective times, once you get to the part where it talks about terms and condition you select some text and press share and then to disable the setup wizzard but this version of the s7 edge basically couldn't make that happen.
The next way was looking at RootJunky video using the OTG stuff and that also couldn't pop up the file manager
Now I'm at the video of people using RealTerm, I followed all the steps till typing the commands into the send section, first command went in fine, but the second one gave me an error, so I restarted the phone and pc, same result, now I'm not sure what to do. I need help! ASAP
