1. Antony Guan's Avatar
    I was helping a friend out with his s7 edge he recently bought off his other friend, and I get the screen that says that this device was reset and needs the previous gmail to verify and unlock this google lock.
    So I went searching for ways, one was with turning on and off the hotspot at respective times, once you get to the part where it talks about terms and condition you select some text and press share and then to disable the setup wizzard but this version of the s7 edge basically couldn't make that happen.
    The next way was looking at RootJunky video using the OTG stuff and that also couldn't pop up the file manager
    Now I'm at the video of people using RealTerm, I followed all the steps till typing the commands into the send section, first command went in fine, but the second one gave me an error, so I restarted the phone and pc, same result, now I'm not sure what to do. I need help! ASAP
    01-17-2017 02:07 PM
  2. Antony Guan's Avatar
    I get this
    01-17-2017 02:08 PM
  3. pankaj981's Avatar
    Why not have your friend reach out to his friend who he bought the device from to help him? Its easy that way.
    Alanhd likes this.
    01-17-2017 04:11 PM
  4. chanchan05's Avatar
    ^what he said.
    Updates are being made to stop all work arounds to that, because that's the entire point, to make the phone unusable if the original owner did not clean it out.
    Contact the original owner.
    01-17-2017 04:34 PM
  5. ratsttam's Avatar
    That's a security feature to prevent a phone that's been lost or stolen from being used by someone else. We cannot help with this here!
    01-17-2017 04:34 PM
  6. Antony Guan's Avatar
    The problem here is that he has never responded to him for the past 2 days, there's a way around it, just keeps getting more difficult as more security patches reach these phones.
    01-18-2017 02:14 AM
  7. Gary02468's Avatar
    That's reassuring. The more difficult it is, the less incentive anyone has to steal these phones.
    If the seller won't help make the phone work, they buyer's only reasonable recourse is to sue him for the cost of the phone.
    WalkingHorse and chanchan05 like this.
    01-18-2017 04:57 AM
  8. B. Diddy's Avatar
    Please do not discuss how to bypass security features. Thread closed.
    pankaj981 likes this.
    01-18-2017 11:22 AM
  1. Replies: 6
    Last Post: 02-07-2017, 02:02 AM
  2. Gear S3 Unpairing on its own?
    By MarqBland in forum Samsung Gear S3
    Last Post: 01-18-2017, 01:48 PM
  3. Phone freezes when powering on.
    Last Post: 01-17-2017, 02:05 PM
  4. How to bypass my Samsung account
    Last Post: 01-17-2017, 01:30 PM
