04-02-2017 11:31 AM
68 123
tools
  1. dryja123's Avatar
    Installed the update and everything went incredibly smooth! Wi-Fi calling is now working consistently, this really saved my phone! Thank you so much for posting this thread.
    Ruben Ocasio likes this.
    01-20-2017 08:16 PM
  2. Ruben Ocasio's Avatar
    No problem glad to share
    01-20-2017 08:27 PM
  3. sweetypie31's Avatar
    Was going to wait, but I'll go ahead and give this a try . Hopefully everything goes smooth. It took me 4 tries to get the mm update on my note 5. I don't even remember what I did to finally get it to work.lol
    01-21-2017 01:08 AM
  4. popkurn611's Avatar
    Let me know how it went, I am Debating on it too
    01-21-2017 06:56 AM
  5. sweetypie31's Avatar
    OK I'm slow and I have questions. After I put the file on my SD card to update do I put the SD card in my phone or leave it in the computer ? After I reboot my phone into recovery mode when do I plug my phone to the computer? Why does the instructions say at the end to repeat all the steps after I've updated on the phone ? I've done this before , but I can't remember how I did it. Lol
    01-21-2017 08:40 AM
  6. Ruben Ocasio's Avatar
    No has to be in sdcard in phone so basically the file needs to be renamed to something like update.zip or software.zip , has to have the .zip at end that way when you go into recovery you select install by sdcard apply sdcard update in recovery, let it do it's thing , be patient will take about 15 to 20 minutes.
    sweetypie31 likes this.
    01-21-2017 08:44 AM
  7. dryja123's Avatar
    The instructions are very clear on XDA.
    01-21-2017 08:54 AM
  8. sweetypie31's Avatar
    For someone who doesn't do this alot it's not clear. Thanks for your input.
    01-21-2017 01:31 PM
  9. sweetypie31's Avatar
    Thanks for your help.
    01-21-2017 01:32 PM
  10. Ruben Ocasio's Avatar
    Np glad to help👍
    01-21-2017 01:33 PM
  11. jaltman's Avatar
    Some have indicated here that release will update OTA when it comes out. Over on XDA they are saying we'll have to downgrade to MM and get the N update OTA. Can anyone clarify why they think the release will come in over the beta?
    01-21-2017 03:57 PM
  12. sweetypie31's Avatar
    Np glad to help👍
    Everything installed and working. Thanks again for the help and answering my questions (even if they might be deemed silly by some lol) .
    01-21-2017 07:55 PM
  13. popkurn611's Avatar
    How do u know which version to install from that list?
    01-21-2017 09:45 PM
  14. dryja123's Avatar
    Look at your baseband version.
    01-21-2017 10:01 PM
  15. popkurn611's Avatar
    OK thanks
    01-21-2017 10:02 PM
  16. popkurn611's Avatar
    I second this question. How would you go about flashing back? Is it a simple process? Will probably have to wipe the phone again
    Est_XCIV likes this.
    01-22-2017 06:58 AM
  17. popkurn611's Avatar
    Np glad to help👍
    Downloaded and running smoothly! This is pretty amazing. I think this software update will keep my away from my pixel now. That's the only reason I've been on my pixel is because of nougat. Now I have the best of both worlds on the s7 edge.
    Is this available for the s7 active? My husband has one and I wanted to update his
    01-22-2017 09:12 AM
  18. Ruben Ocasio's Avatar
    Yes it's available in S7 and S7 Active, S7 Edge all 3, just need to do search on XDA for the S7 Active Thread.
    01-22-2017 09:14 AM
  19. Ruben Ocasio's Avatar
    Should be in here just ask if not find the file link: https://forum.xda-developers.com/s7-...-root-t3473649
    01-22-2017 09:17 AM
  20. popkurn611's Avatar
    Excellent thanks. Not sure if you saw my question before as far as getting the official OTA from AT&T. Will it be necessary to flash back to MM, if so is that an easy process?
    01-22-2017 09:18 AM
  21. Ruben Ocasio's Avatar
    Yes very easy process lot's have answered that on XDA S7 Edge thread, just look on posts or ask over there.
    01-22-2017 09:20 AM
  22. popkurn611's Avatar
    Sounds good, thanks for your help!
    01-22-2017 09:24 AM
  23. Ruben Ocasio's Avatar
    Np glad to help out.
    01-22-2017 09:25 AM
  24. Ruben Ocasio's Avatar
    Few pictures of my own nougat theme
    01-22-2017 09:29 AM
  25. sweetypie31's Avatar
    So when the official att update comes out I'll have to go back mm? I can't just keep this one ?
    01-22-2017 09:50 AM
68 123
  1. lgstylo 2 Android and direct tv have been hacked
    Last Post: 01-20-2017, 02:58 AM
  2. When will i get the nougat update on my galaxy S7 edge
    Last Post: 01-19-2017, 11:31 AM
  3. Samsung Galaxy S7 Edge screen unlock issues.
    Last Post: 01-19-2017, 10:42 AM
  4. S7 Edge after 10 months
    By Jtshurtleff in forum Samsung Galaxy S7 edge
    Last Post: 01-19-2017, 10:35 AM
  5. weird question - s7 back template?
    By NiffiIsenguard in forum Samsung Galaxy S7
    Last Post: 01-19-2017, 10:17 AM
