04-02-2017 11:31 AM
68 123
tools
  1. edubb256's Avatar
    So when the official att update comes out I'll have to go back mm? I can't just keep this one ?
    I'm quite happy with this one and wouldn't mind keeping it, except for issue that I don't know if future security updates will apply over the air to this one.
    When the official update comes out, it is possible that it will update this one OTA and it won't be an issue. I'm assuming though, that I'll have to go back to stock MM (using ODIN) first. I've done that in the past and it is not a big deal to do that.
    sweetypie31 likes this.
    01-23-2017 10:37 AM
  2. osubass1's Avatar
    when i installed, i kept getting a Bluetooth.odex error. now my Bluetooth doesn't work at all.
    the error is: "/system/app/Bluetooth/oat/arm/Bluetooth.odex" had unexpected contents
    oh well...everything else works.
    01-23-2017 10:48 AM
  3. dryja123's Avatar
    Yup, everyone gets the latest ota when it releases.
    Have you received the latest build OTA? I haven't and I'm still running QA4
    02-18-2017 01:59 PM
  4. Ruben Ocasio's Avatar
    You won't get AT&T OTA since QA4 is not official you need to Odin back to Marshmallow APK1 then you will get OTA Nougat QA6 which it's Official AT&T !
    02-18-2017 04:18 PM
  5. dryja123's Avatar
    Which was precisely my initial fear. Flashing back to APK1 is beyond my Android technical skill set. Doing some research on the process now.
    Edit: I found good instructions on XDA and I'm all set.
    02-18-2017 04:34 PM
  6. anon(9780053)'s Avatar
    i noticed a dimmer display contrast and brightness,before only used up to 40 percent bright, now its 60 or more with nougat
    02-18-2017 05:40 PM
  7. popkurn611's Avatar
    It's fairly easy, just have to read carefully! Let us know how it went. I am about to Odin back to MM tomorrow morning.
    02-18-2017 08:48 PM
  8. dryja123's Avatar
    I found solid instructions on XDA and was able to revert to MM and update to QA6 successfully.
    02-18-2017 09:00 PM
  9. popkurn611's Avatar
    Awesome!!
    02-18-2017 09:01 PM
  10. smooches680's Avatar
    Can you please send me the link. I'm new at all this. I'm have the Samsung Beta version.
    02-19-2017 01:21 AM
  11. Ruben Ocasio's Avatar
    Here's the Information i found on AT&T S7 Edge Nougat 7.0!
    Summary:
    Effective February 17, 2017, AT&T released a software update for the Samsung Galaxy S7 edge (SM-G935A).
    This update will be made available to customers to download via firmware over the air (FOTA).
    A Wi-Fi connection is required.
    Device Update/Enhancements:
    Android 7.0 Nougat
    Network performance enhancements
    Samsung Cloud and Samsung Pass
    Removal of AT&T Address Book
    Android device security updates
    Other enhancements
    New Software Specifications Details:
    Software Version: Android 7.0
    Security Patch Level (SPL): February 1, 2017
    Baseband Version: G935AUCU4BQA6
    Kernel Version: 3.18.31-10280464
    Build#: Build Number: NRD90M.G935AUCU4BQA6
    File Size: 1.58GB or 1.64GB
    dm3ready and soldier45 like this.
    02-19-2017 04:35 AM
  12. dryja123's Avatar
    You'll need to grab the APK1 firmware from here: https://drive.google.com/drive/mobil...jBRczBLN3lNZWs
    Watch this video for step by step instructions:
    If you're running QA4 your menu will look different but the steps work just the same. Take it slow, be patient, and carefully follow the instructions step by step.
    Also note that the firmware only works for G935A.
    02-19-2017 06:54 AM
  13. soldier45's Avatar
    Just now getting the OTA Nougat update Sunday 19 Feb via Wifi from AT&T. Will report back.
    02-19-2017 05:26 PM
  14. justin1578's Avatar
    So a developing thread was forming about OTA uodates and it was derailed for a thread that has do with the people that downloaded other versions, then all activity died.
    Well ok then.
    troshs likes this.
    02-19-2017 07:15 PM
  15. Gray Area's Avatar
    Well ok then.
    Lol yup
    02-19-2017 07:22 PM
  16. dryja123's Avatar
    Well ok then.
    Yup, went from a "hooray, the update is here!" back to an old thread where people sideloaded an unofficial version on Nougat and needed help getting the OTA.
    02-19-2017 07:36 PM
  17. DEman19901's Avatar
    After the update,one of most useful widgets(My Places) is currently not available. This sucks....
    02-20-2017 10:49 AM
  18. Ruben Ocasio's Avatar
    I'm on AT&T S7 Edge Nougat Aprils Security Patch !
    04-02-2017 11:31 AM
68 123
  1. lgstylo 2 Android and direct tv have been hacked
    Last Post: 01-20-2017, 02:58 AM
  2. When will i get the nougat update on my galaxy S7 edge
    Last Post: 01-19-2017, 11:31 AM
  3. Samsung Galaxy S7 Edge screen unlock issues.
    Last Post: 01-19-2017, 10:42 AM
  4. S7 Edge after 10 months
    By Jtshurtleff in forum Samsung Galaxy S7 edge
    Last Post: 01-19-2017, 10:35 AM
  5. weird question - s7 back template?
    By NiffiIsenguard in forum Samsung Galaxy S7
    Last Post: 01-19-2017, 10:17 AM
