04-02-2017 11:31 AM
68 123
tools
  1. Ruben Ocasio's Avatar
    Used File Manager to download it size 1.55GB
    Go here for Instructions!
    https://forum.xda-developers.com/att...re-to-t3541329
    dryja123 likes this.
    01-19-2017 11:17 AM
  2. clownin72's Avatar
    I tried to dl it and got the forbidden 493 error
    01-19-2017 11:32 AM
  3. Ruben Ocasio's Avatar
    Need to use a Download Manager , AT&T Has browsers blocked!
    01-19-2017 11:34 AM
  4. Ruben Ocasio's Avatar
    Use this to download it Free Download Manager - download everything from the internet
    01-19-2017 11:36 AM
  5. clownin72's Avatar
    Did you download to the phone or computer to flash with Odin?
    01-19-2017 11:38 AM
  6. Ruben Ocasio's Avatar
    On to Computer Will Post link To Thread , Once it's posted Friend is creating a Thread in XDA With instructions!
    01-19-2017 11:42 AM
  7. clownin72's Avatar
    Awesome. I'll check it out. Thanks
    01-19-2017 11:43 AM
  8. FtaWolf's Avatar
    Download manger want work from phone. You'll need do it from pm.
    01-19-2017 12:02 PM
  9. Ruben Ocasio's Avatar
    Do this zip the file name it update.zip then put on sdcard go into recovery use update recovery by sdcard and install mate.
    01-19-2017 12:08 PM
  10. Ruben Ocasio's Avatar
    First post Updated!
    01-19-2017 01:17 PM
  11. Law2138's Avatar
    Thanks for posting this. Successful sideload of 7.0 this evening using ADB.
    Super simple.
    01-19-2017 06:36 PM
  12. dryja123's Avatar
    So if they tweak the build before it releases it to the masses will you get the updates if you install it today?
    01-19-2017 07:17 PM
  13. Law2138's Avatar
    Yup, everyone gets the latest ota when it releases.
    01-19-2017 07:39 PM
  14. dryja123's Avatar
    Thanks for the info!
    01-19-2017 07:43 PM
  15. tadpoles's Avatar
    I'll wait until aT&t releases it. Looking forwaRd.
    01-19-2017 08:27 PM
  16. edubb256's Avatar
    Super simple.
    I'm tempted. How is it running? Any problems you noticed?
    01-20-2017 09:14 AM
  17. Ruben Ocasio's Avatar
    On my side it's running very smoothly haven't had no issue's at all battery life is even better.
    edubb256, Law2138 and thunderbomb like this.
    01-20-2017 09:19 AM
  18. Law2138's Avatar
    Wifi calling isn't provisioning at the moment. Don't think its a problem with the software, AT&T just hasn't enabled it.
    Battery life is very very good.
    edubb256 likes this.
    01-20-2017 09:34 AM
  19. kcodya's Avatar
    WiFi calling works for me.
    01-20-2017 09:35 AM
  20. Ruben Ocasio's Avatar
    Your correct Wi-Fi calling works like it should now stays on all day at house , while in lollipop it wasn't working the way it should.
    01-20-2017 09:48 AM
  21. Pachycephalosaurus's Avatar
    That's awesome, I was worried AT&T was going to be slow to roll out since we could participate in the beta!
    01-20-2017 12:17 PM
  22. kcodya's Avatar
    Few small things I noticed:
    -Auto brightness is much smoother now
    -Battery life SEEMS to be better, but to early to call right now
    -Wi-Fi seems more responsive now. For example, it won't try to hang on to signal in areas where there is none in my work building.
    -Quick reply and new multi-window are awesome
    Law2138 likes this.
    01-20-2017 12:33 PM
  23. Starr Almighty's Avatar
    I was part of the Beta and Im wondering if they added any new Note 7 features to the Final release Besides the maintenance area/Blue screen filter and notification pulldown tray
    01-20-2017 12:40 PM
  24. edubb256's Avatar
    This update is pretty sweet! Some initial impressions:
    - Install was easy and pretty quick... maybe 30 minutes
    - Everything looks great. I haven't found anything not working (even wifi calling works)
    - Phone is buttery smooth. Animations are like the Note 7, but maybe a tad faster.
    - Built in apps/UI are are slight updates to those on the Note 7, and a little nicer in some places (e.g., pulldown notification panel is more polished)&
    sweetypie31 likes this.
    01-20-2017 01:17 PM
  25. dryja123's Avatar
    I think you convinced me to download the update. I have next to zero service at home and wifi calling has always been spotty. Having stable wifi calling would be huge for me.
    Ruben Ocasio likes this.
    01-20-2017 04:17 PM
68 123
  1. lgstylo 2 Android and direct tv have been hacked
    Last Post: 01-20-2017, 02:58 AM
  2. When will i get the nougat update on my galaxy S7 edge
    Last Post: 01-19-2017, 11:31 AM
  3. Samsung Galaxy S7 Edge screen unlock issues.
    Last Post: 01-19-2017, 10:42 AM
  4. S7 Edge after 10 months
    By Jtshurtleff in forum Samsung Galaxy S7 edge
    Last Post: 01-19-2017, 10:35 AM
  5. weird question - s7 back template?
    By NiffiIsenguard in forum Samsung Galaxy S7
    Last Post: 01-19-2017, 10:17 AM
