1. macka38's Avatar
    Whenever I connect to a WiFi network, a little grey oval with the words, "Failed download" appears on the bottom of my screen. It seems to fade out and back in quickly a couple times after it initially shows up, which leads me to believe there are multiple "Failed download[s]". I have just recently reinstalled my devices firmware through Kies3, and it never did that before I used Kies3. Any ideas?
    Here is a screenshot of the error: https://i.gyazo.com/eb7738c85f34e129c4a3116875006b32.png
    01-20-2017 08:23 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved from the Marshmallow forum to the S7 edge forum.
    Is the phone able to access the web normally otherwise? These kinds of downloads are sometimes related to language dictionaries that are updated in the background.
    01-20-2017 02:10 PM
  3. macka38's Avatar
    Yes, everything works perfectly, just that message is extremely annoying.
    01-20-2017 02:58 PM
  4. B. Diddy's Avatar
    It can be difficult to pinpoint which app is trying to download data. If it were in the status bar, you could long-press it and get the app info, but I'm not sure how to figure it out with these toast notifications.
    EDIT: Try creating a Notifications Log widget on your homescreen to see if it tells you what app was creating the toast: https://www.androidpit.com/how-to-re...ons-on-android. Otherwise, try this app: Notification History
    01-20-2017 04:32 PM
  5. macka38's Avatar
    That found the problem, all I had to do was disconnect from WiFi and reconnect and it told me exactly what it was. Thank you so much! https://i.gyazo.com/785239b44c0c81d1...5707dcb438.png
    B. Diddy and pontiac005 like this.
    01-20-2017 08:40 PM
  1. How to disable mobile data completely?
    Last Post: 01-20-2017, 05:27 PM
  2. Replies: 4
    Last Post: 01-20-2017, 09:04 AM
  3. drop in accuracy, microphone shuts off quickly, S7
    Last Post: 01-20-2017, 08:07 AM
  4. Replies: 0
    Last Post: 01-20-2017, 08:04 AM
  5. Re Samsung S-Health App
    Last Post: 01-20-2017, 08:01 AM
