1. Nicoleannrafi's Avatar
    I already used the device administrator but my SamsungS7Edge is unreachable
    01-21-2017 03:22 AM
  2. Nicoleannrafi's Avatar
    I mean device manager
    01-21-2017 03:23 AM
  3. bandofbrothers2112's Avatar
    The finder of the phone may have turned off the phone or ejected the sim.
    Contact your Network Provider to have the phones imei number blacklisted and the sim barred.
    pontiac005 and sparksd like this.
    01-21-2017 04:31 AM
  4. pontiac005's Avatar
    Hope you at least had a pin or fingerprint locked phone.
    01-21-2017 07:19 PM
  5. sparksd's Avatar
    This exactly - it's so easy to pop the sim out of this phone, defeating locator technology. I just put Android Device Manager on mine yesterday - Sprint disables Samsung's Find My Phone - but it won't help if a bad person picks the phone up.
    bandofbrothers2112 likes this.
    01-22-2017 08:46 AM
  6. D13H4RD2L1V3's Avatar
    ADM will seriously be crippled if the SIM is removed since it removes data capability, meaning that the only way to locate and wipe your device is when it's connected to Wi-Fi and it has its GPS running.
    If you have enabled device protection like having a screen lock and not enabling things like OEM unlocking, wiping your device would not be of much use to whoever has it since the phone would require your Google account password and its corresponding authentication code (if 2FA is enabled, which frankly you should have it so). However, do contact your carrier and have that phone blacklisted soon.
    01-23-2017 02:57 AM
  1. Replies: 1
    Last Post: 01-22-2017, 12:52 AM
  2. hit discard message by accident & can't get out of it help
    Last Post: 01-21-2017, 10:34 PM
  3. Why can't i play video on my htc one m8???
    Last Post: 01-21-2017, 12:06 AM
  4. Replies: 0
    Last Post: 01-20-2017, 11:39 PM
  5. Replies: 0
    Last Post: 01-20-2017, 10:26 PM
