What's new in Nougat for S7 Edge?
pjwk81
754
No Assistant.
There's not much new except the blue light filter and proper AOD. Everything is redesigned though: notification shade, settings menu, stock apps, etc.
lammy8
Trusted Member
Apr 4, 2013
276
No Assistant.
I'm hoping theme makers have made their themes compatible for it. Can't stand all that white.
sweetypie31
4,484
185
63
There's a trash bin in the gallery now where you can restore deleted pics. You have 15 days before they delete permanently. I didn't notice that feature on the note 7.
anon(9408097)
759
Has the user experience of the S7 Edge changed in terms of speed and over all reliability? Not that it had much of an issue before. But just asking.
bandofbrothers2112
Trusted Member
May 30, 2016
2,127
38
A theme can be applied, but many of them have not been updated for Nougat. I tried a couple and you could not see half of the buttons because they matched the color for that part of the theme.
I think as Nougat has been out for this long you'd think other aspects such as Themes would have been updated :(
I use Simply Basic Theme which is a Black Theme.
Would you please mind downloading it from the Theme Store and applying it to see if it has the issues you mention you've experienced with other themes ?
bnutz
