1. aha's Avatar
    Just curious... do we get the new Okay Google Assistant? Anything else?
    Thanks!
    01-21-2017 07:59 AM
  2. pjwk81's Avatar
    No Assistant.
    There's not much new except the blue light filter and proper AOD. Everything is redesigned though: notification shade, settings menu, stock apps, etc.
    01-21-2017 08:02 AM
  3. bandofbrothers2112's Avatar
    There is quite a few reviews on YouTube for Nougat on the s7 edge
    Quite enlightening.
    01-21-2017 08:15 AM
  4. magichoward's Avatar
    I also believe much better battery life
    01-21-2017 01:08 PM
  5. lammy8's Avatar
    No Assistant.
    I'm hoping theme makers have made their themes compatible for it. Can't stand all that white.
    younggreenanne, amyf27 and Gdwheel like this.
    01-21-2017 06:48 PM
  6. smooches680's Avatar
    I'm on the Samsung Nougat beta and still able to use the theme store.
    younggreenanne likes this.
    01-21-2017 08:22 PM
  7. Wizzy's Avatar
    I'm still waiting for the better battery life. I downgraded the display to 1080 and if anything, it's worse than M.
    01-21-2017 09:18 PM
  8. Tsepz_GP's Avatar
    I'm getting great battery life especially in Stand By
    01-22-2017 03:30 AM
  9. bandofbrothers2112's Avatar
    Not surprising on Standby especially if Doze is kicking in.
    LineKill likes this.
    01-22-2017 04:40 AM
  10. Tsepz_GP's Avatar
    Yep, the big thing in Nougat is Doze-On-the-Go, your phone no longer has to be sitting Flat for a certain amount of time to go into Doze, it now shows it while in your pocket.
    KPMcClave likes this.
    01-22-2017 04:57 AM
  11. sweetypie31's Avatar
    There's a trash bin in the gallery now where you can restore deleted pics. You have 15 days before they delete permanently. I didn't notice that feature on the note 7.
    01-24-2017 11:36 PM
  12. lammy8's Avatar
    Can't see this myself, where is it? Could you post a screenshot?
    01-25-2017 12:11 AM
  13. sweetypie31's Avatar
    In the gallery go to the three dots at the top. Click settings and then click on trash.What's new in Nougat for S7 Edge?-1485329780144.jpg
    01-25-2017 01:36 AM
  14. Gdwheel's Avatar
    The new calendar, messaging and emails apps are a step backward, in my opinion. I also dislike all of the white.
    01-25-2017 12:58 PM
  15. bandofbrothers2112's Avatar
    Can't a theme be applied to replace the white ?
    01-25-2017 01:18 PM
  16. Gdwheel's Avatar
    A theme can be applied, but many of them have not been updated for Nougat. I tried a couple and you could not see half of the buttons because they matched the color for that part of the theme.
    01-25-2017 01:23 PM
  17. anon(9408097)'s Avatar
    Has the user experience of the S7 Edge changed in terms of speed and over all reliability? Not that it had much of an issue before. But just asking.
    01-25-2017 02:25 PM
  18. bandofbrothers2112's Avatar
    I think as Nougat has been out for this long you'd think other aspects such as Themes would have been updated
    I use Simply Basic Theme which is a Black Theme.
    Would you please mind downloading it from the Theme Store and applying it to see if it has the issues you mention you've experienced with other themes ?
    01-25-2017 02:39 PM
  19. lammy8's Avatar
    In the gallery go to the three dots at the top. Click settings and then click on trash.Click image for larger version.
    This isn't on the UK version
    01-26-2017 08:45 PM
  20. anon(9408097)'s Avatar
    Have you guys noticed the stuttering while exiting the recent apps screen?
    01-27-2017 04:08 AM
  21. Tarah Sorber's Avatar
    Question for Verizon folks on nougat with their s7 or s7 edge... does it give you the option to block texts? I have a moto z force as well as an s7 edge and my z force before nougat only allowed call blocking.. after nougat i can block both.
    01-27-2017 06:28 AM
  1. Suggestions for a case?
    By vlee in forum OnePlus 3 Cases & Accessories
    Last Post: 05-30-2017, 05:49 AM
  2. Replies: 1
    Last Post: 01-21-2017, 02:55 PM
  3. Number of emails unopened in app notification moto g
    Last Post: 01-21-2017, 11:48 AM
  4. Replies: 0
    Last Post: 01-21-2017, 05:15 AM
