1. LordAndroid's Avatar
    I've noticed in the past couple of days when i place my S7E on the wireless charger and it charges to a 100% the screen turns on for a brief moment right? And after its supposed to turn off well mine isn't turning off after the screen turns on so it sits on the charger @ 100% with the screen on. Its not my screen time out settings because i have that set to 15 seconds of inactivity. Thanks for any help.
    01-22-2017 07:38 AM
  2. trucksmoveamerica#AC's Avatar
    I think it lights up because of that stupid battery full pop up comes on, don't know why it is not turning off. I use my always on display for alarm clock and my phone does not light up at all. Try that, or there's a app that you can disable the pop up, you can try that to, there might be more pop ups you want to disable.
    https://forums.androidcentral.com/e?...token=RA6kwwIi
    01-22-2017 10:38 AM
  3. LordAndroid's Avatar
    https://forums.androidcentral.com/e?...token=NVDYLaRC
    I'll look into this
    01-22-2017 05:15 PM
  1. How To Root Samsung Galaxy Note 5 Verizon ?
    By harshk1 in forum Samsung Galaxy Note 5
    Last Post: 01-29-2017, 09:33 AM
  2. Is it possible to make computers ask for a password when trying to connect to Samsung S5?
    By JustAnotherAndroidUser in forum General Help and How To
    Last Post: 01-24-2017, 01:05 PM
  3. Replies: 8
    Last Post: 01-23-2017, 04:52 AM
  4. Replies: 2
    Last Post: 01-22-2017, 06:18 PM
  5. Edge USB Port ( fast Charging and mtp )
    By Dhruv Kataria in forum Samsung Galaxy S7 edge
    Last Post: 01-22-2017, 04:53 PM
