1. Jessezs's Avatar
    Okay, so this just started happening today.
    When my phone is left unused, if I come after a while and try to turn it on by pressing the home button, nothing happens. It just vibrates, so I press the power button, and bam, everything fine
    A few minutes ago, I tested this again, but now, when I pressed the button, the screen was black, then quickly flickered green. I then powered it up, and everything fine.
    Is there something wrong going on? This phone is second hand and cost me way too much money to have it turn to paperweight. How do I fix this?
    01-23-2017 03:23 PM
  2. amyf27's Avatar
    That doesn't sound good. How long have you had it. Mine doesn't do that, but on mine pretty regularly the notification pull down menu doesn't work at all.
    01-23-2017 03:43 PM
  3. Jessezs's Avatar
    I've had it for a month, loving it, but this really worries me. My previous s5 also had problems with the screen, and it was the main reason I switched.
    01-23-2017 03:49 PM
  4. amyf27's Avatar
    If it's turning colors I'd return for a no chg replacement.
    01-23-2017 04:32 PM
  5. Jessezs's Avatar
    Damn, I can't return
    Second hand and I live all the way in Mexico
    01-23-2017 08:54 PM
  6. amyf27's Avatar
    It should be an mfg defect. Contact samsung.com they have a chat window and phone number to call
    01-23-2017 08:56 PM
  7. Alexsosa's Avatar
    Got the answer. The green acreen appears to occurr a few seconds aftee the always on or night clock turns on. Deactivate those two and the problem goes away.
    05-12-2017 05:25 AM
  1. Replies: 12
    Last Post: 06-19-2017, 10:40 PM
  2. Enable notifications on standby screen? Problem after NoLed uninstall?
    By Marco Arrichiello in forum Ask a Question
    Last Post: 01-26-2017, 05:16 PM
  3. Galaxy S7 suddenly dying at ~40% battery life with no warning
    By Shane B2 in forum Samsung Galaxy S7
    Last Post: 01-24-2017, 05:29 PM
  4. Will the alarm on a MotoG 2nd Gen timeout?
    Last Post: 01-23-2017, 03:16 PM
  5. 'Application low on memory' message on LG G4
    By Stacy D1 in forum Ask a Question
    Last Post: 01-23-2017, 02:33 PM
