1. ma100's Avatar
    In the email application, the ability to collapse sub folders and therefore quickly get to the sub folder you want seems to have gone. Instead you have to scroll through every sub folder..Am I missing something?
    01-28-2017 12:51 PM
  2. Byronh's Avatar
    Any ideas on this.. I have the same
    02-08-2017 03:12 AM
  3. roflynn's Avatar
    I've the same issue too. Anyone know a way around this? I've about 100 folders so this is a real step backwards..
    02-17-2017 03:49 AM
  4. 88keydave's Avatar
    Outlook 365 had this problem before Nougat. I told them about it and they thanked me for the information. But Samsung Mail was working OK at that time. Then Nougat shows up and now Samsung Mail fails same way Outlook does. I have lost control of collapsing and expanding subfolders. This is absolutely unacceptable for an Android upgrade on a premium phone. Don't they even test email before they release the new version? We deserve better than this. I wonder if iPhones support normal subfolder behavior. Come on Google, get this fixed please.
    03-07-2017 08:49 PM
  5. Kathy Delbridge's Avatar
    I too am having the same issue. Is a huge time stealer now. Need the collapse back. This is a huge step backwards
    03-09-2017 03:26 PM
  6. freetail's Avatar
    THIS IS A SHAMBLES. Collapsible folders was THE key advantage of the Samsung Mail app and now with Nougat they're gone. The pre-release version of Outlook Web App has this feature (whereas the Outlook app doesn't) but as far as I can tell can only set up one account so can't switch between or have combined view. Searched for other alternatives and so far, no go.
    Any alternatives guys?
    03-09-2017 05:33 PM
  7. Chima987's Avatar
    03-13-2017 04:16 PM
  8. Chima987's Avatar
    I can't find anything to solve it either. I run duty operations and need to file about 20 to 30 emails every evening. my folder sections are prefixed "S" , so I now have to scroll past over 200 folders before I even reach my filing section. This retarded programming is just diabolical.
    03-13-2017 04:18 PM
  9. Chima987's Avatar
    having said that, i just got a pointer to "nine mail". I have installed it and it lets me run multiple email accounts (exchange server and pop) and allows me to collapse folders and just expand the ones i wasn't expanded. this will do for now, hope it runs okay on other aspects.
    03-13-2017 04:55 PM
  10. scrondar's Avatar
    And yet another reason not to upgrade (yet) to Nougat. Who is breaking all this, Samsung or the providers? I'm keeping my Verizon Edge on 6.01 as long as I can, hopefully long enough for all these complaints to roll back to whomever can fix them. Sorry, but it sounds like Nougat is not really much of an "upgrade."
    03-13-2017 04:59 PM
  11. Chima987's Avatar
    update: whilst nine mail will support exchange and hotmail and 365 etc, it will not support all emails. for example it does not currently support google mail. please check compatibility to your email requirement if looking at nine mail.
    03-14-2017 02:30 AM
  12. Joncast10's Avatar
    Is there a fix for this yet?
    04-05-2017 11:46 AM
  13. mmcnaughton1962's Avatar
    Would just like to know if there is going to be a fix for this. I was on with samsung and verizon forever and neither could fix or give any information as to when it might be fixed :|
    06-02-2017 03:21 PM
  1. Has Smart Lock been removed from the new Galaxy S7 Edge?
    By S_Kinison in forum Samsung Galaxy S7 edge
    Last Post: 02-01-2017, 07:51 PM
  2. Will Nougat allow wi-fi calling integration?
    By spinachie in forum Samsung Galaxy S7 edge
    Last Post: 01-29-2017, 12:52 PM
  3. do the S7 and S7 edge have 100% identical rear cameras?
    By DraftBeer in forum Samsung Galaxy S7
    Last Post: 01-28-2017, 02:13 PM
  4. Anyone know when Nougat is coming to Canada for S7 EDGE?
    Last Post: 01-28-2017, 11:43 AM
  5. How do I delete old/incorrect email addresses
    Last Post: 01-28-2017, 11:29 AM
