Samsung S7 Edge Nougat Update
Piyushs7
5
So i have updated my S7 Edge to the Android 7.0, but there are certain issues with regards to it.
Firstly, its all white and light blue in the drop down menu and notification centre. Any idea how to change that?Cant see clearly because of this.
Secondly,I want to change the theme from white to dark blue or black . Any idea how to do this?
bandofbrothers2112
Trusted Member
May 30, 2016
2,127
38
I'm not on Nougat yet but on my s7 edge on MM I downloaded a Theme from the Theme Store called Simply Basic.
But be aware I read a post recently where the person is on Nougat and the themes they tried hadn't been updated yet. Perhaps trial and error ?
anon(9408097)
759
Go to settings
Then themes and wallpapers
Tap the theme bar
Top right corner, search for 'material'
You'll find one material Gray and blue and another one called material dark
Download both
When they're done downloading, hit apply
You can also search, 'black' And you'll find all black themes
Don't know what others are referring to. These themes work perfectly on my S7 edge running nougat
Good luck.
anon(9408097)
759
Can you please check if the Theme called Simple Basic is working OK with Nougat.
I searched for it and couldn't find it.
I think when people say themes aren't compatible they mean that a lot of themes which were previously available for download aren't anymore.
And I think same is the case with the one you're referring to. Many themes which I had previously installed on marshmallow don't appear on nougat anymore. But some of them do. Maybe these few are the only ones who the developers have made compatible.
Sorry.
But you will find plenty of other simple minimalistic themes.
sweetypie31
4,484
185
63
I don't think you can change the notification center. I used one of the themes and everything changed except for that. It's still white.
amyf27
9,888
224
63
Where are you that you are getting the Nougat update for the S7Edge ? I'm in the U.S. on Tmobile and it's not available there yet
smooches680
1,026
3
38
Go to settings
Tap the theme bar
Download both
Good luck.
I'm on Samsung Beta version for Nougat. And I can access all the themes.
Chelsea rae
