1. Piyushs7's Avatar
    So i have updated my S7 Edge to the Android 7.0, but there are certain issues with regards to it.
    Firstly, its all white and light blue in the drop down menu and notification centre. Any idea how to change that?Cant see clearly because of this.
    Secondly,I want to change the theme from white to dark blue or black . Any idea how to do this?
    01-29-2017 12:54 AM
  2. bandofbrothers2112's Avatar
    I'm not on Nougat yet but on my s7 edge on MM I downloaded a Theme from the Theme Store called Simply Basic.
    But be aware I read a post recently where the person is on Nougat and the themes they tried hadn't been updated yet. Perhaps trial and error ?
    tn_friend likes this.
    01-29-2017 01:47 AM
  3. anon(9408097)'s Avatar
    Go to settings
    Then themes and wallpapers
    Tap the theme bar
    Top right corner, search for 'material'
    You'll find one material Gray and blue and another one called material dark
    Download both
    When they're done downloading, hit apply
    You can also search, 'black' And you'll find all black themes
    Don't know what others are referring to. These themes work perfectly on my S7 edge running nougat
    Good luck.
    smooches680 likes this.
    01-29-2017 03:56 AM
  4. bandofbrothers2112's Avatar
    Can you please check if the Theme called Simple Basic is working OK with Nougat.
    01-29-2017 04:01 AM
  5. anon(9408097)'s Avatar
    I searched for it and couldn't find it.
    I think when people say themes aren't compatible they mean that a lot of themes which were previously available for download aren't anymore.
    And I think same is the case with the one you're referring to. Many themes which I had previously installed on marshmallow don't appear on nougat anymore. But some of them do. Maybe these few are the only ones who the developers have made compatible.
    Sorry.
    But you will find plenty of other simple minimalistic themes.
    bandofbrothers2112 likes this.
    01-29-2017 05:55 AM
  6. bandofbrothers2112's Avatar
    Thank you for looking.
    It comes up as SB in the Theme Store.
    As you say many will and are available to choose from.
    01-29-2017 06:01 AM
  7. anon(9408097)'s Avatar
    Checked SB as well. No sign of it. And also, the theme store is location specific. Maybe it will be available for where you live. Let's hope for the best.
    01-29-2017 08:52 AM
  8. sweetypie31's Avatar
    I don't think you can change the notification center. I used one of the themes and everything changed except for that. It's still white.
    01-29-2017 09:58 AM
  9. amyf27's Avatar
    Where are you that you are getting the Nougat update for the S7Edge ? I'm in the U.S. on Tmobile and it's not available there yet
    01-29-2017 11:35 AM
  10. anon(9408097)'s Avatar
    Screenshot
    01-29-2017 11:39 AM
  11. anon(9408097)'s Avatar
    If you're asking me then I have the UAE version of the S7 edge. Unlocked Dual SIM model. I live in Pakistan though.
    01-29-2017 11:41 AM
  12. trucksmoveamerica#AC's Avatar
    It can be changed, it depends if the theme developer changed it or not.
    01-29-2017 01:51 PM
  13. smooches680's Avatar
    Go to settings
    Tap the theme bar
    Download both
    Good luck.
    I'm on Samsung Beta version for Nougat. And I can access all the themes.
    01-29-2017 03:27 PM
  14. sweetypie31's Avatar
    Screenshot
    My pull down menu did change. I'm talking about this part not changing where the lockscreen notifications are. Samsung S7 Edge Nougat Update-1485730030346.jpg
    01-29-2017 04:47 PM
  15. trucksmoveamerica#AC's Avatar
    My pull down menu did change. I'm talking about this part not changing where the lockscreen notifications are. Click image for larger version.
    Oh that part, mine doesn't change either.
    01-29-2017 04:59 PM
  16. anon(9408097)'s Avatar
    Oh yes. Notifications stay white. As they did in Marshmallow.
    01-29-2017 05:14 PM
  17. Piyushs7's Avatar
    Thank you so much. Help appreciated .
    02-08-2017 11:19 AM
  18. Piyushs7's Avatar
    Yes. And thats what is irritating. Not much clarity there.
    02-08-2017 11:21 AM
  19. Piyushs7's Avatar
    India.
    02-08-2017 11:21 AM
  20. Piyushs7's Avatar
    How did you do this?SB theme?
    02-08-2017 11:22 AM
  21. KPMcClave's Avatar
    The actual notifications portion of the shade cannot be changed without Good Lock, which isn't updated and available for Nougat (yet). Any of the themes will leave that portion white.
    I miss Good Lock.
    02-08-2017 03:54 PM
  22. trucksmoveamerica#AC's Avatar
    I miss Good Lock.
    Thanks, I thought he was talking about the top portion of notifications, I corrected it post #15.
    I will have to check out good lock, I'm not on nougat yet so should work for me.
    KPMcClave likes this.
    02-08-2017 05:48 PM
  23. soldier45's Avatar
    No sign of it on AT&T today 8 Feb. S7 Edge.
    02-08-2017 06:36 PM
  24. popkurn611's Avatar
    You can sideload nougat on an at&t s7 edge. I did it and while it's notifications are much improved, the battery life is still horrendous for me on snapdragon version
    02-09-2017 05:53 AM
  1. Replies: 3
    Last Post: 02-25-2017, 08:08 PM
  2. Carrier role in unlocked phone updates
    By Gweeper64 in forum General News & Discussion
    Last Post: 02-03-2017, 12:33 PM
  3. Samsung S4 won't connect to 5ghz wifi
    By OPZoro in forum General Help and How To
    Last Post: 01-30-2017, 06:00 PM
  4. Why won't my brand now S7 Edge detect my Bluetooth devices?
    Last Post: 01-28-2017, 08:30 PM
