1. George Kimani's Avatar
    Well i was making a docking station for a project at school and then i found that i cannot find a docking station online that has a audio output. It is vital that i complete the project and all i need is to be able to connect a docking station to a speaker so it can play music however i can not find it online. if there is anyone who can help me please let me know.
    01-30-2017 04:24 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Here's one: https://www.aliexpress.com/item/For-...695417107.html.
    01-30-2017 03:15 PM
  3. lizardchest's Avatar
    Unfortunately, the one B. Diddy listed is not available.
    This one may work - https://www.amazon.com/Samsung-SM-ED...cUvbUpU5662775
    B. Diddy likes this.
    01-31-2017 08:05 AM
  4. sparksd's Avatar
    This one may work - https://www.amazon.com/Samsung-SM-ED...cUvbUpU5662809
    I have one of those and when I put my S7E into it a message pops up saying that moisture has been detected in the USB port and it won't work. There is no moisture - I can use the dock with other phones without a problem and I can use any other charger on the S7E without a problem. Strange.
    lizardchest likes this.
    01-31-2017 08:32 AM
  5. B. Diddy's Avatar
    This one may work - https://www.amazon.com/Samsung-SM-ED...cUvbUpU5662900
    Oops, thanks for pointing that out. That unit does seem to be available through eBay, though: Charging Dock Cradle Base w/ Audio Output for Samsung Galaxy S3 S4 S6 S7 S7 edge | eBay
    01-31-2017 09:58 AM
  6. George Kimani's Avatar
    Thanks everyone for your help it is really appreciated now i can rest and continue with my project
    01-31-2017 12:32 PM
  7. George Kimani's Avatar
    Hey guys i found this product: https://www.amazon.co.uk/Samsung-Mul...cUvbUpU5663884. because the others would take long to ship do you think it can work on my s7edge. any replies is helpful
    02-01-2017 04:07 AM
  8. sparksd's Avatar
    Hey guys i found this product: https://www.amazon.co.uk/Samsung-Mul...cUvbUpU5663968. because the others would take long to ship do you think it can work on my s7edge. any replies is helpful
    Doesn't look like it is compatible. See this - I think it's the same one:
    https://www.amazon.com/Samsung-Galaxy-Multimedia-Discontinued-Manufacturer/dp/B009QW3TBK
    02-01-2017 07:00 AM
  9. sparksd's Avatar
    Do you need a docking station as opposed to just using an audio cable in the headphone jack and a regular charger?
    02-01-2017 07:17 AM
  10. B. Diddy's Avatar
    Are you hoping for a dock that won't require you to connect something to the phone's headphone jack? Because that's how it would have to work -- the audio output won't come through the USB port.
    02-01-2017 10:01 AM
  11. sparksd's Avatar
    The edge does appear to support audio out through the USB port:
    https://forum.xda-developers.com/s7-...audio-t3336776
    It just looks like nobody has a dock supporting it.
    02-01-2017 10:05 AM
  12. B. Diddy's Avatar
    I stand corrected -- thanks for the info!
    02-01-2017 10:17 AM
  13. sparksd's Avatar
    No problem. It would seem that there have been changes to Samsung's implementation over time. The Samsung dock I indicated above operates differently for our different phones (tested today):
    Galaxy SIII - full charging and audio out work
    Galaxy Note 4 - charges but audio out does not work
    Galaxy S7 Edge - nothing works and I get the moisture-in-USB warning
    B. Diddy and lizardchest like this.
    02-01-2017 10:45 AM
  14. pappcam's Avatar
    I have the same dock and it worked for the S3, S6 and Note 4 but only did audio for the S3. It doesn't work at all for the S7 so I've purchased a wireless charging stand instead.
    02-01-2017 01:31 PM
  1. Updating to 7.1.1 using custom rom.
    By skid_ in forum Samsung Galaxy Tab4 10.1
    Last Post: 02-04-2017, 03:07 PM
  2. Replies: 1
    Last Post: 01-30-2017, 05:41 PM
  3. Cm security provides my information to any one what can i do
    Last Post: 01-30-2017, 05:29 PM
  4. Home Theater / Speaker setup
    By sudhanjaya in forum Ask a Question
    Last Post: 01-30-2017, 04:23 AM
  5. Replies: 0
    Last Post: 01-30-2017, 04:06 AM
