1. karinagw's Avatar
    I've been getting a pop-up that tells me I need to enable Accessibility Services in Nova Launcher to use them.
    I don't use them. I don't want to to use them. But, I am, apparently, accidentally swiping the screen in such a way that the phone thinks I do.
    Is there ANY way at all to have the phone ignore any gesture that is not specifically defined in the Gesture settings?
    This is getting on my last nerve.
    Thank you.
    Dngrsone likes this.
    01-30-2017 10:29 AM
  2. Dngrsone's Avatar
    Frankly, Karina, I turned it on just to shut the thing up.
    What the setting does is allow Nova to bring the notifications down with a down-swipe from pretty much any part of the screen, such as the swipe you did to cause the notification to pop up in the first place.
    karinagw likes this.
    01-30-2017 11:07 AM
  3. karinagw's Avatar
    Sigh. Thanks. At least, it's mostly harmless.
    But, man, if you have the gesture set to "Do Nothing", you shouldn't get a nag when you do it.
    01-30-2017 11:57 AM
  4. Dngrsone's Avatar
    I hear you. Such is the hazard of using add-ons with added functionality.
    01-30-2017 12:31 PM
  1. What is "switch access" and how do I turn off the message that offers it?
    By 25544 Norad in forum Samsung Galaxy Core Prime
    Last Post: 02-01-2017, 08:40 AM
  2. How to delete pin on lock screen on samsung galaxy note 5
    Last Post: 01-30-2017, 05:44 PM
  3. Replies: 1
    Last Post: 01-30-2017, 05:19 PM
  4. How do you unlock a Tmobile Samsung s6?
    By davidadroid in forum General Help and How To
    Last Post: 01-30-2017, 09:49 AM
  5. Replies: 0
    Last Post: 01-30-2017, 09:31 AM
