Can I set phone to automatically download to SD card?
Sara Di
74
So my S7 Edge is out of space and I have an SD card in there but nothing is saving to it. I read some tutorials on how to save apps to it but they aren't working. Is there a way to change the settings so things download to the SD card first? Or how do I move apps to the SD card? Thanks :)
trucksmoveamerica#AC
Trusted Member
Jul 20, 2010
8,071
660
113
It seems to be a painful process. You have to go to settings, applications, applications manager, then select the app, select storage and then if that app allows it you have to select change, then finally you will get pop up box to check internal or sd card.
Are you storing your pictures, videos, and such media to your sd card?
DragnDon
