View Poll Results: Does your S7 edge have a screen gap?
Voters
1. You may not vote on this poll
  • Yes there is a gap on either or both sides
    0 0%
  • No there is no gap at all!
    1 100.00%
  1. Android104's Avatar
    Hi Guys,
    I have a Samsung Galaxy S7 Edge Gold which I purchased while I was traveling from the Uae.
    The phone had an issue with the home button and I had to eventually send it back to get it repaired.
    The service center in the UAE replaced the entire screen and front panel of the phone and now everything works fine.
    But i noticed the other day that there is a gap in the screen and metal frame of the phone on the left side.
    And through this gap i can see the connector of the volume button.
    The gap is larger on the left side and very minimum on the right side.
    Through this gap light leaks and its very annoying.
    I can easily slide a piece of paper through the gap but I cannot slide a thick business card.
    I am extremely concerned about two things:
    1) Water getting in through the gaps
    2)The light leaking making my screen and device faulty.
    I can see the light leak during the day when the screen is maxed at brightness although it is more visible in a darker environment and also the LED notification light bleeds just a bit from the top gap between the screen and frame.
    I was wondering if this was normal?
    I pray to god that it is as my warranty expires in 2months and I have no one to send my phone back with or otherwise I need to spend 300$ for a repair.
    I have attached pictures... Do let me know what you think.
    Thanks
    Screen Gap S7 Edge gold and light bleeding after repair?Is it normal?-photo-1-31-17-10.55-am.jpgScreen Gap S7 Edge gold and light bleeding after repair?Is it normal?-photo-1-31-17-10.57-am.jpgScreen Gap S7 Edge gold and light bleeding after repair?Is it normal?-photo-1-31-17-10.54-am.jpgScreen Gap S7 Edge gold and light bleeding after repair?Is it normal?-photo-1-31-17-10.54-am-2.jpg
    01-31-2017 12:39 AM
  2. chanchan05's Avatar
    No it's not. I'd take it back to the repair center.
    01-31-2017 02:13 AM
  3. anon(9408097)'s Avatar
    Thank you for this thread by the way.
    I got the S7 edge new and after looking at this post I checked my phone and found the gap with light bleeding through it as well.
    Went to the store and gave it in for replacement. It will arrive in one or two days. Meanwhile they gave me a replacement LGG4.
    Never had an LG. Really liking it
    Will let you know what happens.
    01-31-2017 07:00 AM
  4. Android104's Avatar
    Apparently all phones have a gap but I dont know if this is normal?
    01-31-2017 03:55 PM
  5. Tsepz_GP's Avatar
    Oh my word! Just checked mine!
    The whole way around the frame there is a light bleed, lol!
    My light bleed is even all the way around.
    I've had it in water in a weekly basis when I clean it and no water has made it in.
    This seems to be due to how the Edge Display is built.
    EDIT:
    It seems this a normal thing.
    It's the display between the glass and frame reflecting light especially with lite colours or white.
    I wouldn't worry but it's up to you.
    01-31-2017 04:28 PM
  6. anon(9408097)'s Avatar
    EDIT:
    Hahaha yes mine made a ring around the phone as well. It's good to know that it doesn't affect water resistance. But I still had to get it replaced for my piece of mind.
    01-31-2017 11:53 PM
  7. anon(9408097)'s Avatar
    No all phones don't have this gap. I've had an S7 edge before this. This was my second unit. The first one didn't have this gap. So it's not normal. No no.
    01-31-2017 11:54 PM
  8. Android104's Avatar
    http://downloadcenter.samsung.com/co...1.0_160817.pdf
    Check page 228. It says it is normal on such phones.
    02-01-2017 04:48 AM
  9. Android104's Avatar
    Mine isn't even that is the issue.
    The gap is a little larger on the left side compared to the right.
    Can you slide a piece of paper thorough the gap?
    02-01-2017 04:49 AM
  10. anon(9408097)'s Avatar
    Got the replacement. It has the gap as well but not as bad as the one before. I don't care about it. As people mentioned above, it's normal. And it doesn't affect water resistance so everything is fine.
    And yes I can slide a piece of paper easily.
    02-01-2017 03:57 PM
  11. Almeuit's Avatar
    If I remember correctly from when I had the edge the manual says it's normal for the gap.
    02-01-2017 04:13 PM
  12. anon(9408097)'s Avatar
    Yes yes. A person already posted the link here. Thank you
    02-01-2017 04:34 PM
  13. lammy8's Avatar
    Apparently nobody here understands how light works when passed through glass....
    Unless you can get you fingernail between the glass and metal edge then there's nothing wrong.
    In a dark room turn the brightness up full and display a white screen with a black band along the horizontal axis (get a white wallpaper and colour in a section black in the photo editor). You'll see that you can only see light on the edge from where the part of the display is lit up. The 'bleed' isn't a bleed, just the light being projected out from the edges of the display. Think viewing angles and how light is projected, being so close to the edge it bounces off the metal sides giving the illusion of light bleed.
    02-02-2017 07:34 PM
  1. Google Pixel and Accessories!
    By coldRooster in forum Marketplace Archive
    Last Post: 03-05-2017, 07:27 PM
  2. This phone is amazing.
    By Retinella in forum Moto Z Force
    Last Post: 02-08-2017, 03:10 PM
  3. S7 won't charge. Port dead?
    By Brad Oxford in forum Samsung Galaxy S7
    Last Post: 01-31-2017, 11:30 PM
  4. Why does my screen stop responding?
    Last Post: 01-31-2017, 12:06 AM
  5. Replies: 0
    Last Post: 01-30-2017, 11:41 PM
