I need a little help. Im using nova on the s7 edge. There is this ugly black shadow on top of my homescreen. It looks terrible whenever im using a colorful/white/bright wallpaper. You can even notice it when using a darker wallpaper if you look close enough. Is there anyway to remove it? or is that build into Samsung? I know it's not nova doing. thanks
things i've tried
- turned off notification bar in nova launcher
- put Transparent on notification bar
- turned off shadow in advanced setting in nova/desktop setting
- uninstall nova launcher
- reset factory setting
Noted * it show up at smartwiz / default launcher as well.
also, if I go into gallery and preview the wallpaper, the black shadow isnt there. but when i applied the wallpaper it shows up, you can see it the attachments.
There is no way they put that ugly shadow in there on purpose.
things i've tried
