1. Tuanie Panda's Avatar
    I need a little help. Im using nova on the s7 edge. There is this ugly black shadow on top of my homescreen. It looks terrible whenever im using a colorful/white/bright wallpaper. You can even notice it when using a darker wallpaper if you look close enough. Is there anyway to remove it? or is that build into Samsung? I know it's not nova doing. thanks
    things i've tried
    - turned off notification bar in nova launcher
    - put Transparent on notification bar
    - turned off shadow in advanced setting in nova/desktop setting
    - uninstall nova launcher
    - reset factory setting
    Noted * it show up at smartwiz / default launcher as well.
    also, if I go into gallery and preview the wallpaper, the black shadow isnt there. but when i applied the wallpaper it shows up, you can see it the attachments.
    There is no way they put that ugly shadow in there on purpose.
    Attached Thumbnails Homescreen shadow-screenshot_20170131-221507.jpg   Homescreen shadow-screenshot_20170131-221536.jpg
    02-01-2017 08:57 PM
  1. Saving file to homescreen
    By furbymac in forum Google Pixel & Pixel XL
    Last Post: 11-30-2017, 08:26 PM
  2. Homescreen background "resetting"
    By menneentalvenlumia in forum OnePlus 3 & 3T
    Last Post: 01-27-2017, 10:54 AM
  3. Replies: 6
    Last Post: 01-20-2017, 01:17 PM
  4. How to create shortcut from website to homescreen
    Last Post: 01-19-2017, 03:45 AM
  5. Replies: 0
    Last Post: 01-16-2017, 02:06 PM
