02-09-2017 05:47 PM
111 ... 345
tools
  1. WingLT's Avatar
    It's more involved when trying to install 7.0 from the Beta.... Number one when the update comes out you will have to uninstall the Beta 7.0 through Odin and reinstall the carrier one. If you don't do this then you won't get updates for your apps and every thing else... I also haven't seen any methods using just a SD Card for the zip file. Everything on YouTube I seen involves Odin... I don't suggest doing this because you can brick your phone. So until I see a safe way of doing this, and getting the right zip file easily I won't do this... I tried finding the zip file for Sprint and every topic I looked at involved Odin....
    As for Samsung delaying the Update, it's bull**** now. It's been many months and the update should have been out in November. it's totally insane. The reasons I want the update is for the better battery manager options, better AOD, the way it looked, and many other features that are not available on Marshmallow...
    02-06-2017 10:52 PM
  2. Tsepz_GP's Avatar
    I have sideloaded nougat and I can tell you it's not buggy, so for the delay to occur is inexcusable. It's quite an improvement from marshmallow so I'd be frustrated as well. Many of us techies want the latest and greatest on their devices. I mean we spend $700+ dollars on these devices. Apple, Google, and Motorola all come out with timely updates except Samsung. It's a big downfall for the company and I'm starting to steer away from buying Samsung devices.
    Unlocked Moto Z only just begun getting Nougat:
    http://www.phonearena.com/news/Andro...Moto-Z_id90706
    HTC 10 Update was also paused and just recently resumed:
    http://www.androidauthority.com/htc-...esumes-747474/
    Seems there is something in Nougat that has caused issues for some OEMs.
    Most have been late with it.
    02-07-2017 12:12 AM
  3. widget2k13's Avatar
    just had an update on my s7 edge this morning hoping it would fix the message preview problem but it hasn't , instead its stuck a facebook app onto my homescreen, more crap built in now and no way of removing it, not everyone uses that rubbish
    pankaj981 likes this.
    02-07-2017 02:53 AM
  4. bandofbrothers2112's Avatar
    What update was it ?
    I certainly don't want the Fb App on my phone either!!
    02-07-2017 12:15 PM
  5. widget2k13's Avatar
    it says build number nrd90m. g935fxxu1dqb3
    02-07-2017 04:36 PM
  6. DEman19901's Avatar
    Android needs updates like Apple does no reason waiting for updates to come out. Apple sends out updates to almost every device with no issue.
    That's why I am done with Samsung. Only Pixel from here on out.
    02-07-2017 04:55 PM
  7. popkurn611's Avatar
    I went back to my pixel BC I got tired of Samsung....So happy with the pixel. The s7 edge has so many pros over the pixel but they aren't significant enough to me to triumph over the software experience and battery life of the pixel.
    02-07-2017 06:05 PM
  8. amyf27's Avatar
    What about when the Note 8 comes out. Are you guys going to stick with the Pixel then? I see why some are going that route with the recalls etc. I'm willing to try them again
    02-07-2017 06:59 PM
  9. popkurn611's Avatar
    I downsized to the regular pixel and love the size, I'll never buy a note. Too big for me.
    02-07-2017 09:14 PM
  10. ThrottleJohnny's Avatar
    That's why I love Android. There's a phone for Everyone
    02-07-2017 11:37 PM
  11. Ddust14's Avatar
    I'm just waiting on Oreo for my GS8 plus..
    DEman19901 likes this.
    02-09-2017 05:47 PM
111 ... 345
  1. Root for Galaxy S5 running Kitkat 4.4.2 for Nordic countries
    By Margit11 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 02-04-2017, 01:38 AM
  2. Backlight issue. Missing top and bottom panels on HTC 826.
    Last Post: 02-03-2017, 06:56 AM
  3. Replies: 0
  4. Why will my WiFi work for some things, but not others?
    Last Post: 02-03-2017, 06:23 AM
  5. My Le Eco 2 does not update to nougat 7.0?
    Last Post: 02-03-2017, 05:06 AM
